Shooting film of DLP projection
9 replies to this topic
#1 Frank Barrera
Frank Barrera
  • 473 posts
Posted 09 March 2007 - 09:16 PM
Shooting S16MM at 24fps of an actor standing in the beam of an image playing down from a DLP projector. Will there be any flicker? I have no idea how these projectors work. Anyone?
thanks much
#2 John Sprung
John Sprung
  • 4635 posts
Posted 14 March 2007 - 02:46 PM
thanks much
DLP's get their dynamic range by duty cycle modulating the individual colors for each pixel. The possible different algorithms to do that must number in the gazillions, and could be changed as software updates. Bottom line, the only thing to do is test with the actual playback material and projector to be used. That being said, most of them probably switch fast enough as not to be a problem.
#3 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 14 March 2007 - 05:11 PM
I wouldn't see any reason for there to be any flicker with film, if you were using video that might be a different matter, all the same, get a test done.
Better to be safe than sorry. :lol:
#4 ryan_bennett
ryan_bennett
  • 138 posts
Posted 15 March 2007 - 04:36 PM
What do you think the film shutter does? The question is whether the projection of a video image would cause problems on the screen. Are you projecting things off a computer? Then maybe you can full around with the cycle speed or whatever it's called. Personally you need to run tests and maybe fool around with shutter speeds, especially if the actor is just staying still or something.
#5 Christopher Schneider
  • 24 posts
Posted 16 March 2007 - 05:01 AM
You should not have any flicker problems. I've shot DLP projections without changing the shutter and had no flicker problem. I even shot a film with an image slide show burned to DVD and projected through an older DLP projecter, the stills were on screen for long periods of time with no flicker what so ever. Also, they looked beautiful in the final film, crystal clear and solid.
Good Shooting!
#6 Frank Barrera
Frank Barrera
  • 473 posts
Posted 26 April 2007 - 09:36 PM
soooo... although i have yet to see the footage myself the director finally called me back to tell me that there was no flicker... sigh...
#7 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 27 April 2007 - 12:51 AM
For future reference, it seems like a DVX100 would be a good tool to preview flicker in situations like this.
#8 Ian Bloom
Ian Bloom
  • 8 posts
Posted 14 December 2007 - 12:01 AM
I've set up a rear projection test with a Dell MP5100 DLP projector and a Red, and I'm experiencing a lot of flicker at 1/48th shutter. It looks tolerable at 355 degree shutter, but I don't want to make that choice creatively. I'd rather shoot 180 degree. Any ideas? Is this a projector issue or a electronic shutter issue.
Also we noticed alot of RGB strobing on forground objects moving through the frame as you can see in this image:
Ian Bloom
Edited by Ian Bloom, 14 December 2007 - 12:04 AM.
#9 James Meagher
James Meagher
  • Electrician
Posted 22 February 2011 - 05:37 PM
I am about to shoot a live ballet with lots of DLP projections and some LCD projections involved in the staging. I am shooting with 3 HVX200s, and will have very limited time to run tests before filming begins - so if anyone has some initial insights on what I should expect and how to go about this I would love to hear it!!!
Cheers,
James
#10 Juanita Rodriguez Onzaga
Posted 29 December 2012 - 06:21 PM
I am going to shoot a film in 16mm where there is a rear projection using a DLP projector (Optoma HD72i).
Is there anybody that has obtained flicker with a DLP projector? Should I invest in renting an LCD projector or would it make no difference?
Thanks!
