A Few Questions on Electrics
#1 Daniel Smith
Daniel Smith
  • 791 posts
Posted 12 March 2007 - 02:30 PM
Hi.
I just have a few questions on electric that I couldn't really find anywhere else. (That and I didn't think about them on the shoot I done last saturday)
1. What is the purpose of a 'ballast'?
I've looked through google and the best answer I found was to regulate the current going into the light. So it's kept on 'x' watts for the duration of it being turned on, to avoid any electrical damage.
If this is the case then, are powerful lights prone to this sort of damage without ballasts? Or is it just a precaution for the unlikely but worst?
2. How do major productions power their lights?
On a recent shoot with 'Phil Rhodes' we had to plug the 6kwatt HMI's in to the theatre next door. From my understanding the average U.K household has about 30amps to play with. Which is quite low when you start adding up the power consumption of a lot of these studio lights.
So, if there's no theatre nearby, and you've got a selection of huge lights to play with, how do you do it?
Thanks.
Dan.
Edited by Daniel Ashley-Smith, 12 March 2007 - 02:33 PM.
#2 Phil Rhodes
  • 12176 posts
Posted 12 March 2007 - 03:25 PM
No. A cloud of ionised gas - that is, gas that's had its electrons knocked off by electrical bombardment - as exists between the electrodes of a working HMI is a superconductor with practically no resistance. With no resistance, current flow would increase theoretically infinitely until something went "bang".
Ballasts also provide the high voltage starting pulse, but that's not really part of their theoretical function as a ballast - that's just something that happens to be in the same box, which we refer to, for simplicity, as "a ballast."
Studio power, or a generator. Both are extremely expensive.
I believe the company fuse - which regulates the total load to each home - in the UK is usually 60 amps. Every ring main is supposed to be fused at 32, and there's usually at least three in a modern home - upstairs, downstairs, and a private one for the kitchen. This means you can't pull 32A off all of them at once, and the sockets are fused at 13A, so you can't have all 32 for one device.
The 6K HMIs we had on Saturday were each pulling 6000/240=25A of current from the 32A outlets, more than you could ever get out of any sort of domestic supply.
Phil
#3 Kim Sargenius
Kim Sargenius
  • 73 posts
Posted 25 March 2007 - 07:34 PM
Does this refer to any particular 'Phil Rhodes' or just a general 'Phil Rhodes' type personality? :P
Sorry, I'll stop the phil-bashing right now... :)
Kim Sargenius
#4 David Mullen ASC
Posted 25 March 2007 - 07:51 PM
Ballasts are for AC gas discharge-type lamps generally, like HMI's, flourescents -- not normally for ordinary tungsten lamps. Size isn't the issue -- a 20K tungsten doesn't use a ballast, but a tiny 200w HMI does. Your ordinary hardware-store fluorescent lamp has a ballast inside the unit.
Typical household circuit in the U.S. is 20 amps, although some are smaller like 10 or 15 amps. This is why a 2K tungsten or a 1200w HMI is normally the most powerful lamp you can plug into an ordinary wall outlet.
Generators are typically used for movie shoots; not only do they have to provide enough power, but they have to be crystal-controlled to prevent AC flicker, and they have to be silenced in some manner for sound shooting.
#5 Riku Naskali
Riku Naskali
  • 310 posts
  • Finland
Posted 17 May 2007 - 03:28 PM
Getting power is indeed difficult. On student shoots we usually try to get three-phase power from some nearby buildings/warehouses/commercial spaces, etc. for free, or for almost free. Generators would of course work, also you could get electricity from the distribution boxes(?) that electrical company owns. I don't know if you have them overseas, but we have them scattered around our cities. You pay them a fee and they will rig a box for you.
#6 Phil Gerke
Phil Gerke
  • 59 posts
  • Sound Department
Posted 18 May 2007 - 12:14 AM
Phil
Hi Phil,
I just wanted to check something with your math. My understanding is that with HMI you cant just devide the watts by the volts and get your amperage. This is true for incandescent, but I thought that did not quite work for HMI, or anything with a ballast for that matter. Am I missing something? Our 800 Joker pulls 14 amps on 110, so what gives? I'm just trying to get my facts straight for the future.
Thanks a lot!
#7 Rob van Gelder
Rob van Gelder
  • 158 posts
  • Steadicam Operator
  • Bangkok, Thailand
Posted 18 May 2007 - 01:25 AM
Phil (Gerke, in this case),
There are basically 2 types of ballast: the -older- magnetic ballast and the electronic ballast.
The last version has two types as well; with power factor correction (named PFC or ALF) or without it.
In efficiency, the magnetic ballast is the worst, the electronic with PFC/ALF is the best.
This means that with a magnetic ballast you have to put in a lot more energy (watts) to feed the same HMI bulb.
Also the magnetic ballast is much heavier and bigger than a similar wattage electronic ballast.
I am not sure about the efficiency of a magnetic ballast, but the electronic without PFC/ALF is around 69%, with the PFC/ALF 98%.
So the current you draw from the mains supply can be approx 30% higher when using a non-PFC/ALF ballast and probably even higher with a magnetic ballast.
There are more problems related to not-PFC equipment, but that goes too far to explain here, i think.
