Dolly track
#1 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 15 March 2007 - 10:38 AM
I am in the process of building my own dolly track. I'm going to use T6061 Auminum tubing instead of steel or stainless to conserve on weight. I'm not concerned with the softness of the aluminum vs. steel track as it will only be used on our productions. Would a .25 inch wall thickness be stiff enough (same as Speedrail), or should I consult a Mechanical Engineering, Strength of Material text?
#2 David Erlichman
David Erlichman
  • 49 posts
  • Grip
  • Toronto, Ontario, Canada
Posted 15 March 2007 - 12:26 PM
My buddy makes this track:
www.gitrack.com
It's aluminum and can deal with the weight.
Edited by David Erlichman, 15 March 2007 - 12:26 PM.
#3 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 15 March 2007 - 02:45 PM
My dolly track have aluminum tubes with diameter 40 mm and thickness 2 mm.
I use of my dolly system more 3 years and don't have any problem with surface of tubes.
The dolly can carry two or more mans and big crane.
yes, of course, if i can i prefer of tubes 50 mm x 3 mm.
#4 Jesus Sifuentes
Jesus Sifuentes
  • 116 posts
  • Texas
Posted 24 May 2007 - 09:43 PM
www.gitrack.com
Man that is wicked! We have been drawing prototypes for a jib. Will post on the forums.
