white balance in HD cam
#1 william koon
william koon
  • 82 posts
Posted 16 March 2007 - 09:59 PM
(1) Can I do white balance in this HD camera or preset it to tungsten/daylight?
(2) How do I get the approximate ASA for this camera?
Thnx
#2 Michael Collier
Michael Collier
  • 1262 posts
Posted 16 March 2007 - 10:54 PM
Yes, white balance is set through a built in filterwheel on the camera and through an electronic balance like any ENG camera. preset balance or electronic balance likewise are set through standard switches (A-B-PRE).
ASA I am not sure of, but you can find it precisely with a lightmeter and a waveform monitor. Search these forums theres a post with the procedure explained. Keep in mind changes to the set-up can affect the asa value. Most cameras I have used are between 250-400 on tungsten setting, most landing at 320.
#3 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 16 March 2007 - 11:55 PM
Most people generally rate the Varicam at about 640 ISO. White balance can be set easily using a white balance detection switch on the front of the camera. The preset can be switched from tungsten to daylight but note that the filter wheel is marked in offsets based on tungsten balancing. If you want to shift the camera's white balance, you can set an offset in the menus. This is a nice feature if you perhaps want a consistently slightly warm look, where you set the camera to shift the image a couple hundred degrees warm relative to a white balance detection.
#4 william koon
william koon
  • 82 posts
Posted 19 March 2007 - 12:50 AM
Thnx Mic & Mitch
#5 Ken Minehan
Ken Minehan
  • 168 posts
  • Singapore
Posted 29 March 2007 - 11:58 PM
I hope this helps.
The ASA rating for the varicam is as follows
ND filter 1 and color correction filter B: 640 ASA
ND filter 1 and color correction filter C: 400 ASA
ND filter 1 and color correction filter D: 250 ASA
ND filter 2 and color correction filter B: 160 ASA
ND filter 2 and color correction filter C: 100 ASA
ND filter 2 and color correction filter D: 64 ASA
ND filter 3 and color correction filter A: 40 ASA
ND filter 3 and color correction filter B: 25 ASA
ND filter 3 and color correction filter C: 16 ASA
ND filter 4 and color correction filter A: 10 ASA
ND filter 4 and color correction filter B: 6 ASA
ND filter 4 and color correction filter C: 4ASA
I hope you can follow this. sorry if it's confusing.
regards
Ken Minehan
#6 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 30 March 2007 - 12:57 AM
Another link:
http://www.jkor.com/...varicamasa.html
#7 Ken Minehan
Ken Minehan
  • 168 posts
  • Singapore
Posted 30 March 2007 - 02:56 AM
sorry i made a mistake. please see below for revised version
ND filter 3 and color correction filter B: 40 ASA
ND filter 3 and color correction filter C: 25 ASA
ND filter 3 and color correction filter D: 16 ASA
ND filter 4 and color correction filter B: 10 ASA
ND filter 4 and color correction filter C: 6 ASA
ND filter 4 and color correction filter D: 4ASA
regards
Ken Minehan
