Cut the Run/stop sound (beep) on an Arri SR3 ???
#1 Thibaut de Chemellier
  • 108 posts
  • Paris
Posted 20 March 2007 - 03:44 PM
Silly question : How do you cut the Run/stop sound on an Arri SR3 ???
I can't see the way in the manual...Help
#2 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 20 March 2007 - 04:38 PM
salut thibaut
tu as 3 boutons en facade : sel set et mode
presse mode puis sel jusqu'a voir des petits traits en bas de l'ecran digital :
ces traits signifient le style du bip, passes par tous les choix en declenchant a chaque fois pour verifier.
bonne chance
#3 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 20 March 2007 - 05:18 PM
Can someone post the response in English as well? I am sure plenty of people that don't speak French would like to know the answer as well.
The gist I could pick up was to use the three buttons on the body and navigate to the menu that allows you to set the style of the beep, and then to select "no beep" (or verifier).
#4 Dennis Kisilyov
Dennis Kisilyov
  • 152 posts
Posted 20 March 2007 - 11:34 PM
salut thibaut
bonne chance
Hi Thibaut,
There are 3 buttons on the digital panel: SEL SET and MODE
Press MODE and SEL until you see a underline/menu on the digital display.
This underline selects the type of beeping. Verify your selection by triggering the camera.
Good Luck.
Incindentaly it also selects a few other things, like fps lock and variable and constant frame rates, I have not a clue if this is right.
Edited by Dennis Kisilyov, 20 March 2007 - 11:36 PM.
