Widescreen Mask for Regular 16mm Bolex
#1 Steven Wyatt
Steven Wyatt
  • 91 posts
  • West Yorkshire, UK
Posted 21 March 2007 - 09:48 AM
Heya,
Upgrading my Bolex to super 16 is abit beyond my budget, so would it be possible to install a widescreen mask in the viewfinder that could enable one to frame for 1:78:1 and not 4:3.
Comments would be appreciated.
#2 Dory Breaux DP
Dory Breaux DP
  • 291 posts
  • Fort Bragg, CA
Posted 21 March 2007 - 01:03 PM
Heya,
I do this on MiniDV cams all the time. If you want an exact aspect ratio, thers gonna be a little math involved, but I usualy just guess it and apply masking tape to the VF.
#3 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 21 March 2007 - 02:02 PM
well - its depends on which bolex you have...
All the prisms I've seen will swing out from the body to show the top of the ground glass, which is where the mask is placed, held down by two screws ... On my RX4 it would be as easy as putting some tape strips down on top of that, the SB and EL i own have another convex-planar magnifying lens installed with the mask sandwiched in between.. Maybe you could just put tape on top of this lens, or try getting to the mask itself ...
In essence the mask could be put anywhere in the viewfinder path where the rays are coherent - the prism mask itself is probably the easiest ...
Some measurements that maybe helpful:
10.26mm x 5.96mm = usable image dimensions on neg for transfer
9.65mm x 5.42mm = all things being equal this is the 'correct' size for the mask
#4 Steven Wyatt
Steven Wyatt
  • 91 posts
Posted 22 March 2007 - 11:35 AM
Thank you guys so much!
#5 Antonio Bunt
Antonio Bunt
  • 134 posts
Posted 28 March 2007 - 06:55 PM
How about the same masking for the Russian K3?
