ZOOM LENSES ON MOUNT ADAPTERS
#1 Mike Medavoy
Mike Medavoy
  • 36 posts
Posted 22 March 2007 - 11:59 PM
Do you run more risks mounting a 35mm ZOOM lens to a 35mm camera by way of a mount adapter (as supposed to a prime for example)?
I am not talking about weight and support, obviously the zoom lens will be properly supported etc etc
I am talking about zoom drift, lens displacement and so on. A prime is smaller and doesn't have moving elements, and generally doesn't take as much strain as a zoom lens, therefore mounting it with a mount adapter is safer I assume. But what about a zoom lens? People do this if they have no choice?
Thanks!
Mike
PS Specifically, the zoom is in Bayonet mount and I will mount it on a BNCR camera by way of a Bayonet-to-BNCR adapter. The adapter is reasonably sturdy and in good condition. The lens is the Angenieux 12-240 converted to 25-500mm for 35mm format.
#2 Jon Kukla
Jon Kukla
  • 399 posts
Posted 23 March 2007 - 12:19 AM
I would think that a zoom would be better in that I could at least use it to quickly check for any change in backfocus. But in essence, assuming that everything is securely locked in and the lens is supported properly, I don't see any reason why there should be problems.
