What is the B-Stretch Setting?
#1 Scott Tranchitella
Scott Tranchitella
  • 2 posts
Posted 24 March 2007 - 05:30 PM
I am using a Panasonic WV-F500 with AU-45 MII Desk and I noticed the B-Stretch setting in the Head unit menu. What does this do? Anyone have a WV-F500 manual?
#2 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 24 March 2007 - 06:17 PM
You'll probably want to leave that the black stretch in the "on" position at all times. To see what the black stretch does, simply point the camera at a contrasty scene and then turn the Black stretch setting on and off. What you will probably see is lower level black level signals blend together into one black glob of no definition when black stretch is turned off.
Where you will probably notice how hideous having the black stretch off is when shooting someone with black matted hair. Assuming your camera was from the 90's era, it is possible that your camera will instantly create a 70's look with the black stretch turned off. I don't know if panasonic with the black stretch off put out as grim a picture as the Hitachi Z-one-C did with it's black stretch off, but if it did, you will just want to leave it "on" at all times because you can always crush the signal when you edit, but uncrushing what you did while shooting basically becomes impossible.
