How was this done?
#1 yamir bhatt
yamir bhatt
  • 1 posts
Posted 27 March 2007 - 11:14 AM
I was debating how to show products falling in absolutely clean water ..generating rounded bubbles.. just like in lots of Smirnoff commercials. One AD told me they must have actually used vodka as it is very clean. On the other hand some say alcohol is less dense then water so the product will fall too rapidly, in that case Glycerin comes to mind. Has anyone shot ?Smirnoff type?/ ?stuff in clean liquid? shoot?Posted Image
#2 Don Bachmeier
Don Bachmeier
  • 31 posts
Posted 27 March 2007 - 06:19 PM
It is a still image (istock) so most likely strobes; and possibly an optical trigger.
No telling how much Photo Shop was involved in the image. In fact the whole thing could have been assembled in Photoshop. A recent episode of Photoshop TV showed a similar image made from a seperate splash and a bottle image.
With film, and slow motion, a high frame rate and syncro-strobe lighting or a whole bunch of level from continous sources.
with DVAM, probably not. The apple would have moved through the shot in less than the time it takes to capture the frame. Zip, a blur at best.
Cranking up the shutter speed would make a slower playback speed choppy looking.
Get a fish tank and give it a go. Check back with the results.
Always looking for new ways to do things.
Good luck,
#3 seth christian
seth christian
  • 189 posts
  • Nashville, TN. USA
Posted 15 April 2007 - 06:38 PM
real easy dude.
half the time they just take a perfect clear/clean fish tank and fill to desired
water level where the frame wont show anything above or below to
composition. then shoot shot upon drop of apple. shazaam!
however, you're not gonna get a quality shot like the one you showed with
DV, unless its an HVX200 or better. I'd recommend using a still 35mm camera
and just dropping until you think you got it. And, expect to possibly photoshop
out undesired reflections. As well as shooting with at least a 1000 shutter speed
to capture no blur.
Edited by seth christian, 15 April 2007 - 06:40 PM.
#4 Chris Keth
Posted 15 April 2007 - 10:28 PM
Distilled water helps this kind of shot. It has less stuff in it and will make fewer ugly little frothy-looking bubbles. There will also be fewer bubbles clinging to the sides of your tank.
The difficult thing is keeping everything clean of dust. You would be surprised how much dust there is to make your water look all mucky.
#5 Gavin Greenwalt
Gavin Greenwalt
  • 225 posts
Posted 19 April 2007 - 01:25 AM
Be warned they're also using more and more fluid sims in vodka commercials. The "perfect splash" could be a fake.
Edited by Gavin Greenwalt, 19 April 2007 - 01:25 AM.
