SKIP bleach + PUSH process = ?
#1 Rajavel Olhiveeran
Rajavel Olhiveeran
  • 115 posts
  • India
Posted 31 March 2007 - 02:09 AM
hi all
i had earlier skip bleach processed directly on the negative for a small flash-back sequence. it worked interestingly. though the exterior shots were little blown out more than i expected....
how will a negative react if i am gonna under expose by two stops and combine the SKIP bleach process with the 2 stops PUSH process???
normally push process saturate the colors right? how do we achieve the High contrast + high color saturation chris doyle's films!!
thanks cheers!!
  • 20068 posts
Posted 31 March 2007 - 10:08 AM
You wouldn't skip bleach, that's for sure -- that lowers saturation. You're leaving black silver in all the color layers.
Doyle basically pushed-processed a 250T stock for that saturated contasty look, plus shot saturated subjects in colored lighting. At least that's how he shot "Fallen Angels". He didn't skip-bleach. And it's debatable whether push-processing really improves saturation as opposed to simply getting a denser negative and printing it down.
In other words, if you exposed normally and pushed one stop and thus had a negative that was one-stop overexposed, then printed that down, would it look any more saturated than a negative that was overexposed one-stop, processed normally, and printed down? Is it the pushing or the extra negative density that is improving the color saturation in the print?
Cross-processing an E6 reversal stock like 5285 would get you super high contrast, high saturation.
#3 Rajavel Olhiveeran
Rajavel Olhiveeran
  • 115 posts
  • India
Posted 31 March 2007 - 12:31 PM
THANKS MR.DAVID
#4 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 01 April 2007 - 12:12 AM
For more info:
http://www.cameragui...ting_limits.htm
#5 Jon Kukla
Jon Kukla
  • 399 posts
Posted 01 April 2007 - 06:27 AM
And remember that if you DO ever use skip bleach, you need to underexpose the film by about a stop (and beef up your fill light).
