100' Super 8
29 replies to this topic
#1 Jim Simon
Jim Simon
  • 93 posts
Posted 07 April 2007 - 11:10 PM
My company's first film is in development now, and principal photography is slated for October of this year. I'll be taking up both the Director's hat as well as the DP. One of my concerns is that shooting at 24 fps, I'll get less than three minutes per roll. With slates and pre-roll, that ain't much time for actual footage.
I understand there are Super 8 cameras that can use rolls larger than 50'. Can anyone shed some light on these cameras and their operation?
#2 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 08 April 2007 - 07:21 AM
I recently shot a super-8 short and used 18 frames per second instead of 24 frames per second, this results in an additional 50 seconds from each Super-8 film cartridge. From a practical standpoint of how easy it will be for me to make a tape to film copy it may be more complicated because I chose 18 Frames per second instead of 24, otherwise I'd recommend it for you. I like the look at 18 frames per second and the additional 50 seconds of filming time per cartridge plus the 1/3 of a stop gain in sensitivity is a bonus.
I don't recall if all the kinks were ever worked out of the supermag, which was supposed to allow for up to 400 feet of filming at a time. I personally think that 200 feet at a time would be adequate but other than the Beaulieu and special film orders from Wittner in Germany, I don't know if anyone else is offering anything. for extended film run time in Super-8.
Has anyone successfully used 18 frames per second and basically did whatever they wanted with the final edit master, either in NLE or as a high resolution videotape master? You might want to have a digital video counter made just in case you are swapping film cartridges in and out of your cameras. It's more accurate than the footage counter.
#3 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 08 April 2007 - 10:45 AM
The only other real option at the moment is a DS8 camera that runs 100ft daylight spools, but your limited to 2 reversal stocks. I would stick with 24fps and just work with changing carts... it's not that bad.
#4 Lisa Davidson
Lisa Davidson
  • 35 posts
Posted 08 April 2007 - 04:53 PM
How much does it cost to buy film and have it reperforated? Then you could use anything you liked. I suppose you order 100' of Super 8, if it comes that way, and then have the other side perfed. (I think.) Because otherwise, you'd have to order 100' of unperforated 16mm and then have both edges done.
#5 Jim Simon
Jim Simon
  • 93 posts
Posted 09 April 2007 - 01:23 AM
OK. More info on that, please. What camera models might use such a mag? Has anyone here ever used one?
I may have to. But there are a few scenes that run longer than a single 50' roll will cover. Thus the inquiry over longer rolls.
#6 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 09 April 2007 - 09:16 AM
"OK. More info on that, please. What camera models might use such a mag? Has anyone here ever used one?"
I believe that any super 8 camera that was designed to use the discontinued 200ft cartridges can accept the Supermag 400.
#7 kevin jackman
kevin jackman
  • 350 posts
Posted 09 April 2007 - 11:09 AM
the whole reperfing thing has been visited numerous times. it would cost 50 grand to get the machine then you have to get the unperfed film to do it with. chances are it would have to be cut down from 65mm. its not an option really worth looking at at the moment.
the ds8 bolex and pathe ds8 can theoretically do 400ft loads of ds8. im looking into this more myself at the moment to see if the mags can run at the ds8 speed instead of the 16mm speeds.
#8 Jim Simon
Jim Simon
  • 93 posts
Posted 09 April 2007 - 03:04 PM
...any super 8 camera that was designed to use the discontinued 200ft cartridges...
And those would be? (Make/Model)
I checked out the Bolex. For that price, I can probably move to 16mm.
The Pathe is spring loaded and probably not a good choice for shooting sync.
#9 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 09 April 2007 - 03:35 PM
2.5 minute scene or shot? If it's a scene, don't worry... if it's a 2.5 min shot, then thats just wierd :blink:
Edited by Anthony Schilling, 09 April 2007 - 03:36 PM.
#10 Ryan Ball
Ryan Ball
  • 74 posts
  • Los Angels
Posted 09 April 2007 - 06:46 PM
The 50ft cartridge helps you learn to be economical in your shooting, which will serve you well in other formats as well. You have to know what you want when you get on set and not just shoot a bunch of footage and try to figure it out in editing. Plus, your film will be more interesting because you can use those roloading breaks to set up and shoot from a different angle. Guys who shoot video tend to just let the camera run like they're shooting a stage play and the result is a dull movie. How many times have you watched a professional film and saw a cut that lasted a full 2.5 minutes? That's a lot of screen time.
#11 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 09 April 2007 - 08:32 PM
"And those would be? (Make/Model)"
This is not a definitive list but here are some super 8 camera models that can accept 200ft cartridges.
Chinon Pacific 200/8XL
Chinon Pacific 200/12XL
Elmo 230 S-XL
Elmo 240 S-XL
Nizo 6080
Remember that not many cameras were made to take 200 feet of film so your choice is a bit limited here.
There was a review of the Supermag 400 in an issue of 'Super 8 Today' some time ago.
#12 Terry Mester
Terry Mester
  • 323 posts
  • Welland, Ontario, Canada
Posted 09 April 2007 - 11:27 PM
Hi Jim,
As Alessandro noted, 18 f/s should look as good as 24 f/s. There isn't likely a Pulldown Ratio in place for converting 18 f/s Film to 25 & 30 f/s Video. If you can find a place that can specifically programme their Telecine Machine, I can come up with a Pulldown Ratio for converting 18 f/s to both Video speeds. However, as I noted in my Thread "Converting 20 Frames / Second to Video" in the Telecine Forum, you can easily convert 20 f/s Film to 25 f/s Video with a 2:3 or preferably a 2:3:3:2 Pulldown, and to 30 f/s Video with a basic 3 Pulldown. 20 Frames / Second will give you 3 Minutes per 50 foot Cartridge.
#13 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 09 April 2007 - 11:54 PM
The final version of sound super-8 cameras that many manufacturers
made would accomodate the 200 ft. cartridge, such as the Elmo 1012XL,
the Elmo 612XL, The Nizo 6080 and perhaps a few other Nizo four digit model
numbers, but I'm not sure if all four digit Nizo model numbers accomodate the
200 ft cartridge. Elmo also made some simpler cameras that took the 200 ft cartridges
but only had 3-1 or 4-1 zooms whereas most other 200 ft cartridge capable cameras
usually had at least a 6-1 zoom ratio. The Canon 814XLS and 1014XLS also can take
the 200 ft cartridge, as can the Beaulieu 7008. The Beaulieu 5008 might also take
the 200 footers. I think there might be some Chinon's and Minota's that take the 200
footers as well.
If you own a camera and there is a removeable plate on the top of the camera above
where the film cartridge is placed then your camera probably can take the 200 ft load.
But at the moment, no one is making 200 ft cartridges although there are some pre-loaded
film magazines for some of the Beaulieus but they are pre-loaded in Germany, I think???
#14 Jim Simon
Jim Simon
  • 93 posts
Posted 10 April 2007 - 12:31 PM
I thank you for the directorial suggestions, but the scene itself may well run over the time available when shooting at 24fps (which I am decided on). That doesn't mean it will end up being one shot. I've already planned on three camera angles to cover the scene. All this will be edited together in post. But the scene itself is particularly dramatic, and I feel it might be better for the actors if they're allowed to just run through each take without breaks.
If it's economically feasible, I'd like to avoid what happened to Cameron when shooting The Abyss, where he ran out of film while shooting the scene where Mary Elizabeth Mastrontonio was being revived.
To the others, thank you for the model listings. If anyone has any experience working with such cameras and larger mags, please post any advice here.
#15 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 10 April 2007 - 02:22 PM
Hi Jim,
Just to point out, the workflow options for 18 frames per second work appears to be much more limited if one is thinking of making a tape to film print later on.
#16 Robert Houllahan
Robert Houllahan
  • 1626 posts
  • Providence R.I.
Posted 10 April 2007 - 03:11 PM
Hi
Our color lab head Bob Hume and I were talking about 100' super8 cartridges just yesterday. Bob said that Kodak used to make 100' loads that were in the same 50' cartridge. They managed this by putting the film on estar base. Bob said that they did not really work well because the thinner base routinely jammed in the cartridge making it more like a 30' roll than 100' maybe 50' is alright after all.
-Rob-
#17 Daniel Smith
Daniel Smith
  • 791 posts
Posted 10 April 2007 - 06:28 PM
Hi, this is just a really quick question, nothing to do with the thread exactly but it's better than starting a new one for such a simple question.
I'm considering trying some super 8 out and was worried to see that Kodak were only offering 200T and 500T for colour. If I'm thinking correctly, then they are both tungsten balanced. Which means Kodak doesn?t actually do a daylight colour film in super 8 anymore.
Is this correct or have I messed something up? Tnx!
(And sorry for hijacking things for a few moments)
#18 Matthew Buick
Matthew Buick
  • 2345 posts
  • Newcastle upon Tyne, UK.
Posted 10 April 2007 - 07:00 PM
How about Ektachrome 100D? You can get it from pro8mm and ANDEC. :)
You'll love Super 8. :)
#19 Daniel Smith
Daniel Smith
  • 791 posts
Posted 10 April 2007 - 07:14 PM
Wasn't even aware of it until now... I'm going by what's listed on kodak.co.uk
Shows how much I'm into super8!
Cheers Matt.
#20 Jim Simon
Jim Simon
  • 93 posts
Posted 11 April 2007 - 02:36 PM
Getting back on track...
A forum search turned up a few hits about where one might buy 200' loads, but all the posts are old, as are the links in them.
Is anyone familiar with where 200' loads can currently be purchased? Anywhere in the US maybe?
