Looking for a Sankyo XL 620 Supertronic Manual
#1 Craig Mieritz
Craig Mieritz
  • 26 posts
Posted 09 April 2007 - 01:09 PM
Hi-
Wondering if anyone has a copy of the manual for this camera that they'd be willing to share (or if they know of where one is available online). I've spent a fair amount of time searching all over the web and could only find one place in the U.K. that had it available. They wanted about $50 for a download of the manual.
Thanks.
#2 Terry Mester
Terry Mester
  • 323 posts
  • Welland, Ontario, Canada
Posted 09 April 2007 - 11:25 PM
What specifically about the Camera do you not understand? I have a different Sankyo -- which are very well-built Cameras by the way, and I may be able to answer your questions. Matthew Buick also has a Sankyo, and much experience with it.
#3 Craig Mieritz
Craig Mieritz
  • 26 posts
Posted 14 April 2007 - 10:17 PM
Thanks for the reply and the offer of assistance. There is nothing in particular at this point. I just like to have as much info available as possible.
Actually, now that I think of it, there is one thing. What would you recommend using to replace the foam in the door? I got the old slimy stuff out and am thinking about what would work best (and not make another mess).
Best Regards
Craig
#4 Terry Mester
Terry Mester
  • 323 posts
Posted 16 April 2007 - 05:08 PM
Craig, are you talking about the foam around the Door Window? If so, just cover it over with black vinyl electrical tape. That's all I did. You can verify that there's a Cartridge inside by checking the footage Meter.
You should have a screw 'socket' on the Right Side of the Camera when looking at it from the front. That's called a Cable Release Plug Socket used for 'single frame' shooting.
#5 Craig Mieritz
Craig Mieritz
  • 26 posts
Posted 16 April 2007 - 05:35 PM
OK. Thanks again.
#6 Terry Mester
Terry Mester
  • 323 posts
Posted 17 April 2007 - 09:17 PM
Another suggestion I would make is to look into the Lens with a Flashlight to see if there are any scratches on the internal Pink Filter. They call it a UV Filter, but it actually serves the purpose of reducing the excess Blue Light you can experience on a cloudy or overcast day outside. If you can see any scratches, then just insert a screw on top to push out the Filter. I had to do this on my Camera due to scratches. Luckily, I discovered the scratches before first using it.
#7 Craig Mieritz
Craig Mieritz
  • 26 posts
Posted 23 April 2007 - 12:16 PM
Thanks for the replies. I actually found an original manual on eBay for a reasonable price. Persistence....
#8 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 25 April 2007 - 04:44 AM
You're the only person that I know of that has ever claimed there is a pink UV filter inside the camera.
#9 Terry Mester
Terry Mester
  • 323 posts
Posted 25 April 2007 - 06:44 PM
What colour are you proposing that it is? It's not Red. A Pink Filter is used to soften excess Blue Light. I looked this up in professional photography specifications! Before first using my Camera, I damned well wanted to know what that Filter was for. It doesn't matter whether you're talking about Photography or Cinematography, Filters for colour correction are the same.
