DALSA Evolution
64 replies to this topic
#1 Ilmari Reitmaa
Ilmari Reitmaa
  • 71 posts
  • Helsinki, Finland
Posted 10 April 2007 - 08:57 AM
Copy-pasting from a DALSA news release:
DALSA Digital Cinema reinforced its leadership in 4K motion picture capture today with the announcement of new 4K camera models, an on-board 4K data recorder and new 4K anamorphic lenses. The new products will be on display at the upcoming National Association of Broadcasters (NAB) trade show (booth # C-9423), April 16th to 19th, 2007 in Las Vegas.
"Basically, we?re talking about the ability to shoot at 4K resolution, 16-bit, uncompressed, untethered, using the highest quality anamorphic lenses. I think cinematographers will be particularly thrilled that, for the first time, a digital camera will be able to capture the CinemaScope 2.40:1 aspect ratio without compromising image quality."
Available "early 2008".
#2 Andrew Ray
Andrew Ray
  • 45 posts
Posted 10 April 2007 - 09:04 AM
Does it mean that there are no good lenses out there that can work with the full 4k format?
Are there any lenses that can resolve 400Lp/mm and could be used with the cine type camera?
Andrew
Edited by AndrewR, 10 April 2007 - 09:06 AM.
#3 David Mullen ASC
Posted 10 April 2007 - 10:19 AM
I don't know if the new Dalsa camera solved this problem, but they had this problem that the sensor was a little larger than Super-35 and thus some 35mm cine lenses would vignette on it.
I'm glad to hear that Dan Sasaki is designing anamorphic lenses for the camera, although with a 2x1 sensor, the Dalsa was the one camera that I thought didn't really need anamorphic lenses, since you could either crop a little to get scope (and also deal with any vignetting in the corners) or crop a little the other way to get 1.85. Maybe they changed the shape of the sensor too, to something closer to 16x9.
I get to go to a Dalsa presentation tonight so I'll learn more.
#4 John Holland
John Holland
  • 2273 posts
  • London England
Posted 10 April 2007 - 10:27 AM
So are they doing a presention in L.A prior to NAB ?
#5 David Mullen ASC
Posted 10 April 2007 - 10:33 AM
Yes, tonight for the ASC over at the Dalsa headquarters.
#6 John Holland
John Holland
  • 2273 posts
  • London England
Posted 10 April 2007 - 10:36 AM
That sounds very interesting , be nice to hear what you learn .
#7 Lance Flores
Lance Flores
  • 124 posts
  • San Antonio/Dallas/Detroit
Posted 10 April 2007 - 11:00 AM
I received a vip invitation to one so I would say yes. I've settled on the Dalsa since no one else is ready for a 4K feature production with a camera directly compatible with our workflow and provides what I want for the capture.
#8 Max Jacoby
Max Jacoby
  • 2955 posts
David,
Obviously the word 'anamorphic' makes me salivate already :P
I'm sure you'll ask what the squeeze factor of these lenses is. Since the chip is 2:1 one would only need a 1.2 squeeze, which would yield a look closer to spherical than anamorphic. Also is the anamorphot at the front or at the back? And finally what focal lenghts, size and speed these lenses come in.
#9 Lance Flores
Lance Flores
  • 124 posts
Posted 10 April 2007 - 11:43 AM
David,
List of lenses available:
List of Lenses
#10 Brian Drysdale
  • 5196 posts
Posted 10 April 2007 - 01:10 PM
List of Lenses
Unfortunately that's their current spherical lens rental list.
If new lenses have such a small squeeze factor, they'll lose one of the nice side effects of the current anamorphic lenses: a long focal length for a particular horizontal angle of view.
#11 Lance Flores
Lance Flores
  • 124 posts
Posted 10 April 2007 - 01:51 PM
Yes. I'm not too concerned. I'd rather not soften things and can compose the shots to work for the story. As we work through previz we can work out feel we need with the DoP and 2nd Unit DoP/stdycm. We'll have lenses made for us if need be.
Edited by Lance Flores, 10 April 2007 - 01:52 PM.
#12 John Holland
John Holland
  • 2273 posts
  • London England
Posted 10 April 2007 - 01:53 PM
Soften things ?
#13 Andrew Ray
Andrew Ray
  • 45 posts
Posted 10 April 2007 - 03:02 PM
Soften things ?
Gentleman, as you see from post number, I am new here.
I do underwater and cave exploring and filming.
We would like to move to 4K format this year and from our limited experience we see that there are no lenses on the popular market that will have resolving power to support 4K sensor, that is about 200 photo sensing sites per mm. Equivalent of 100Lp/mm
The lenses have to have minimum double of that so 90% of resolving power will be preserved. We, as well as most of people here on this forum, are new to 4K.
Can anybody help us with good advice on this subject, please.
Andrew
#14 Brian Drysdale
  • 5196 posts
Posted 10 April 2007 - 04:11 PM
Andrew
Perhaps you should contact a motion picture lens manufacturer like Cooke who will might be able to give you more details.
http://www.cookeoptics.com/
Also Zeiss cine/motion picture lenses.
http://www.zeiss.com/photo
You'll also find details of the Zeiss lenses here:
http://www.arri.com
Under cameras - lenses & accessories
Dalsa list these companies lenses as part of their 4k lens rental list.
#15 Andrew Ray
Andrew Ray
  • 45 posts
Posted 10 April 2007 - 04:48 PM
Thanks! Brian.
We tested Zeiss UP and MP and Cooke S4 and anything below 65 do not have sufficient 200Lp/mm resolution away from the center of the frame. Also chromatic aberration is limiting the resolution to less then 100Lp/mm except the very center of the frame.
I was thinking about some lenses that are designed for 70mm format and the adapter to PL mount, along this lines?
#16 Brian Drysdale
  • 5196 posts
Posted 10 April 2007 - 05:03 PM
The 65 mm shooting format lenses wouldn't be as modern as the 35mm lenses.
#17 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 10 April 2007 - 05:04 PM
Well the Master Primes are the sharpest lenses available anywhere. 65mm lenses are less sharp, because of the increased size of the negative compared to 35mm does not require such high optical performance. The Arri 65mm lenses are all rehoused Zeiss medium format stills lenses released in the early 90s.
#18 K Borowski
K Borowski
  • 3905 posts
Posted 10 April 2007 - 06:22 PM
As someone that shoots 6x7 cm film almost every week, let me tell you, you're worrying too much about edge sharpness falloff. As is, that happens with all lenses. As long as you have a lens that has enough coverage for the full frame, the jump in resolution is going to be dramatic. People's eyes have resolution falloffs aroudn the edges too, you know, even 35mm film is going to have falloff around the edges, not drastic, but definitely there. I know Zeiss is sharp glass, but it's not THAT much better than every type of lens everyone else makes.
Even Zeiss is going to have distortions and aberrations. We live in the real world after all. *Nothing* is perfectly formed, that is impossible, especially when it comes to lenses.
I think that you should look to the movie equivalent of 6x7, which would probably be 15-perf 65mm to see how they deal with loss of resolution around the edges. My personal bet on what they'll say, is that they ignore it. This isn't going to be noticeable vignetting like in the first silent movies, unless your lens doesn't cover the whole sensor.
Frankly, with digital, you should be more worried abou the light from the rear element of the lens not hitting the sensor from a perfect normal angle. Otherwise it causes all kinds of aweful distortion. I'm sure the current line of 16mm-sized HD lenses and 35mm-full frame digital sensor-compatible lenses have been redesigned with a flattened rear element, but be very cautious before you go slapping a large format film lens in front of a digital sensor. You might not like what you see. . .
Also, let's just get this straight, because lp/mm is probably the most misunderstood and abused principle in all of imaging: The resolution of a SYSTEM is inversely equal to the inverse of the sums of each of its component elements:
So we have a frame of 4-perf Super 35. I'm going to round, and use English Units where I see fit, hope you don't mind:
I have a sharp sharp Supersharp Superexpensive lens that I bought, resolving 200 lp/mm, right off the bat, in line pairs/inch that correlates to 5080 lp/in. I have a film that resolves your typical 63 lp/mm in average real-world lighting conditions (note that digital also suffers from a loss of contrast when not shooting test charts, but I am not going to go into that issue here. I have no desire to start a ten-page long debate on the merits and demerits of either medium today). 63 lp/mm is equivalent to 1600 lp/in. Let's just assume that the Super 35mm 4-perf frame is close enough to 1 in by 3/4 of an in. so it will make my calculations much easier. The total area of the frame then is 3/4 of a square inch. That is the area upon which waves of light are focused by the lens.
Therefore the inverse of the resolution of the master negative (resolution sub total) (not including optical printing, contact printing, scanning, film-out, shrinkage during processing of acetate stocks, etc.):
1/(res.-sub-tot.) = 1/(5080lp/in.) + 1/(1600 lp/in.)
res.-sub-tot. = 1216.7665 lp/in.
This is a 2-D measurement, so we have to take both the length and height
of the frame, respectively, and multiply each of these dimensions by the
corresponding number of line pairs per inch of 2D dimension, then multiply
the two resultant products together:
(1216.7665 lp/in. x 1 in.) x (1216.7665 lp/in. x 0.75 in.) =
(1216.7665 lp width) x (912.575 lp height) = 1110390.507 lp^2 frame area
Since a line pair is two lines, and two lines times two lines equals four lines,
multiplying this area by four gives us 4441562 and change "waves"
of resolution. This is only about 4.4 megapixels equivalent worth
of information that can be resolved on the S35 4 perf frame,
which would, assuming greater sweetspot and lens coverage would
correspond to 8.9 megapixels on a frame of Vistavision. Again, if you
increase sweet spot, stop down two from wide open, and have enough
effective coverage, the f-stop acts to limit lens falloff around the edges.
Stop down anymore than two stops and you run into aberrations from light
glancing off the f-stop blades, which would cause another type of distortion.
Note that the 200lp/mm lens still takes 25% of the resolution away from the film, so your statement that you'd retain 90% of the information on the sensor is incorrect. It would be even lower with 1- or 200 lp/mm sensor sites. Honestly, I don't think that those sites can possibly resolve all 200 sites unless you're shooting black lines on white boards illuminated by studio lights. At 1000:1 contrast, you'll get resolutions around 1-300lp/mm with modern slow color negative films. It's not film that is the limiting factor here, or digital, it is and always will be the lens, regardless of the size. Note that 5 perf 65mm is about 2 1/6 in. x 9/10 in. (39/20 in.^2) This is 2.6 times larger than the area of the 4 perf Super 35 frame, so, as long as your new lens covers the whole area of the negative, it can actually have far WORSE resolving power, because the neg area has increased the resolution othewise to 260% of the 35mm negative. It is often the case that still photographers shoot with 100-year old lenses on their 8x10 inch or larger view cameras. The area of the negative is so huge that you could shoot with the lens Daguerre was shooting and still outresolve a DSLR or 35mm.
This is assuming that every beam of light that hits the lens is somehow in sharp focus all at once. We needn't worry about F-stops and chromatic aberrations right now though, they'll come into play later, though it's too complicated to sample calculations without specific data from a lens; even among the same model aberrations and distortions will vary, significantly from lens to lens. The only way around this problem is to basically act like you're Stanley Kubrick when you go to the rental house and individually check and test EACH of their lenses with resolution charts (again keeping in mind that resolution at chart contrast can be more than an entire order of magnitude greater than the resolution of the lens with real-world contrasts you'll encounter when actually shooting)
I hope this makes sense. I tried to make it coherent in the time I had to write it.
Take care,
~KB
#19 Lance Flores
Lance Flores
  • 124 posts
Posted 10 April 2007 - 06:37 PM
Thanks! Brian.
Andrew - you are exactly on point. I've working through similar issues. I'm having three complete sets of 70mm lenses made.
#20 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 11 April 2007 - 02:16 AM
By whom? You are taking medium format lenses I believe?
