Kinor 35H Lubrication, need help!
#1 Pritchett Cotten
Pritchett Cotten
  • 7 posts
Posted 10 April 2007 - 10:56 PM
I've looked far and wide on the net, and have found essentially nothing about lubricating the Kinor 35H. I did read the information on lubing on the recent post titled "Good Kinor Sites." This is the best info I've found, but it didn't give me a good sense of exactly what to do. Does anyone have any good info on how to lubricate the camera and mags (if they need it too)? Is the lubrication process similar to a Moviecam? Does anyone have any photos demonstrating how to do it? Any information anyone could provide would be most helpful. I'm kind of at a standstill with the camera cause I don't want to run it without oil!!
#2 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 10 April 2007 - 11:51 PM
Go to commiecam.com and look up Olex's sight. He's got a lot of stuff on Kinor 35s and actually on any Russian cam you can think of. If I'm not mistaken, there's a lube photo section there in the kinor section as well.
Here are a few more adresses though Kinor places are far and few between:
konvas.org (Has kinor too but not much)
rafcamera.com
www.geocities.com/russiancamera
www.cinemods.com
www.konvas.info/v/dan/
konvas.com/
These are all I've found so far. If you come up with any new sites, please let me know. Thanks B)
#3 Pritchett Cotten
Pritchett Cotten
  • 7 posts
Posted 13 April 2007 - 09:57 PM
rafcamera.com
www.cinemods.com
konvas.com/
Thanks for the information Steve. I checked out Olex's site, there was some good information, but I did not see any about lubrication. I did get in contact with Steve Morton through the site you provided, but again no concrete info about it. Thanks again, and I'll let you know if I find more sites and info!
#4 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 13 April 2007 - 11:19 PM
I found another sight. It's not about lubrication but it is interesting. www.lomoscope.com/xlr_how_to-Pages/xlr_005.html
Actually you want to start here: www.lomoscope.com
#5 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 15 April 2007 - 12:07 AM
I got this e-mail from Olex, I don't know if it will help or not, but here it is:
Hi Steve.
=Thanks for the information, Olex. Do you have any diagrams or photos
for
=lubricating the Kinor 35H.
I don't can show you of all points of lubricating of Kinor-35 H,
because, the some parts can be service with take to pieces of a few
modules and panels only.
The very important condition of lubricating of axis of mirror disk and
other parts.
But, the basic lubricating you can do personally.
If you open of lid of camera and check of all parts of transport
mechanism, you can see a few holes with red circuits. This is points of
lubricating.
( Sorry, I don't have pictures and don't have Kinor-35 at service new
for shoot of this points ).
This is axis of film rollers and axis of transport mechanism.
If I remember correct, a some version of transport mechanism have holes
for lubricating, closed of small screws, you need unscrew of this screw
and you will open of hope with oiled tissue pin.
Other, you will need oil of all surfaces of all transport and
registration pin parts.
Any case, I recommend you ask of professional camera technician do this.
Best regards
Olexandr
For What it's Worth.
#6 Pritchett Cotten
Pritchett Cotten
  • 7 posts
Posted 20 April 2007 - 11:41 PM
Thanks for the info. I'll take a look at it with these directions. They are a little different than the ones on the other forum.
#7 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 20 April 2007 - 11:47 PM
What other forum? B)
#8 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 21 April 2007 - 07:58 PM
I've looked far and wide on the net, and have found essentially nothing about lubricating the Kinor 35H. ...
I have written about this before, but:
On the 35H cameras I have seen, which is only a handful, there is an extremely rinky-dink "bearing" on the back of the motor, where the crystal circuit's optical encoder has been added to what evidently was originally a pilot signal recording camera. This is under high tension from the tight timing belt. It is a very badly conceived add-on with a plain steel shaft running in a plain aluminum "bearing." This is one reason why I stopped doing crystal updates to USA circuitry on the 35H cameras.
Without constant oil, the "bearing" will start to screech and seize up, jamming the camera. To get to it you have to partly disassemble the camera. To be safe you might have to do this every 1000 feet of running.
This aluminum "bearing" should be replaced by a qualified machinist with a long sintered bronze bearing or preferably a pair of actual ball bearings, in order to be a reliable assembly. This aluminum sleeve is an incredibly sleazy modification to what otherwise seems to be a fine camera. As I said, I don't know if all 35H cameras have this problem. Hopefully yours has been updated?
#9 Pritchett Cotten
Pritchett Cotten
  • 7 posts
Posted 22 April 2007 - 04:17 PM
Sorry, not "forum." I meant another 'posting' titled "Good Kinor Sites" within the Kinor forum on cinematography.com. I just looked back to it and it was info on lubrication that you had posted before! But what you just posted had a few different things listed. I still need to sit down with both lists and work with it. Thanks again!
