pentax m42 mount lenses on a krasnogorsk-3?
#1 Stacy R Fillion
Stacy R Fillion
  • 19 posts
  • Burnaby B.C.
Posted 21 April 2007 - 01:24 PM
Can this be done? Will the aperture work correctly?
#2 Sir Alvin Ekarma
Sir Alvin Ekarma
  • 211 posts
Posted 21 April 2007 - 01:51 PM
Yup. Standard operating procedure. Make sure the lens is set to Manual and you're all set.
#3 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 21 April 2007 - 01:57 PM
Ive got a takumar 200mm and a tamron 400mm and they work fine on the K3. The only thing is that the takumar won't focus on infinity so I might have to get that lens adjusted by an expert oneday.
#4 Stacy R Fillion
Stacy R Fillion
  • 19 posts
  • Burnaby B.C.
Posted 21 April 2007 - 02:59 PM
"Make sure the lens is set to Manual and you're all set."
I assume you meant automatic. Is there some sort of attachment so that you can set the aperture manually
Edited by S.R.Fillion, 21 April 2007 - 03:01 PM.
#5 Sir Alvin Ekarma
Sir Alvin Ekarma
  • 211 posts
Posted 21 April 2007 - 05:51 PM
My M42 lenses have a switch near the base and markings for Manual (M) and Automatic (A). Most M42 lenses have this but if they're the automatic kind w/ a pin, you need to disable that.
#6 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 21 April 2007 - 09:34 PM
NOPE MANUAL.
In the still camera the lens is stopped down by a pin in the back just before the shot, this will not work for movies, so the lens must be run on manual so it is stopped down all the time. A few of the lenes don't have the manual setting so they must either be modified or traded.
Noote that the lenses for the Sportmatic f have the switch but it will not go into manual Unless a small pin near the threads is pressed in. I am not sure if the K-3 will press this pin. You may have to press it, and set the lens on manual beofre mounting it on the camera.
