Filter for forest scene
#1 tommy holman
tommy holman
  • 19 posts
  • 2nd Assistant Camera
  • London, UK
Posted 22 April 2007 - 09:43 AM
hey,
i am currently about to shoot a short film on super 16, and one of the scenes is set in a dense forest with alot of de-saturated greens and browns. As the film has different colour palletes for each scene, the forest scene is supposed to be the 'green scene'. Is there anyway i can increase the saturation of green in the scene without losing detail. I have heard they do a green enhancing filter, but arrimedia in the uk do not stock it! Any other suggestions??
Tommy Holman
Posted 22 April 2007 - 12:05 PM
Well, if you are going to telecine this footage, the simple answer is to play with the green saturation in post.
On the set, wetting down greens, painting greens greener when possible, or bringing in fresh green plants to dress the location would help.
Other methods are not so effective -- you could somehow flash the negative with green light using a VariCon device (needs a 6x6 mattebox), this would fog the shadows & blacks green. You could put a light green filter on the camera and light faces with HMI's with a magenta gel to compensate.
#3 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 22 April 2007 - 12:29 PM
Other methods are not so effective -- you could somehow flash the negative with green light using a VariCon device (needs a 6x6 mattebox).
Will a VariCon fit in my Ultracam 5X6 mattebox? Obviously I'd have to blackwrap and gaff tape the top of the filter and mattebox to keep stray light out.
#4 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 22 April 2007 - 12:53 PM
Fuji daylight stock seems to have a nice sensitivity to "forest green". If the variation in light is too extreme, you may want to consider a low con or ultra con filter, starting perhaps in the #1 strength.
#5 Tony Brown
Tony Brown
  • 689 posts
Posted 22 April 2007 - 02:52 PM
Green foliage is always a tricky subject.... always has been. Keep the leaves backlit if possible to punch the colour through otherwise I've used a lot of smoke lit with big units with a light green gel, works great for interiors.
