depth of field charts
#1 douglas bergossi
douglas bergossi
  • 1 posts
Posted 22 April 2007 - 05:33 PM
hello everybody
i'm looking for the depth of field chart of this series
if anybody knows where i can find it it will be great
thanks
#2 Frank Barrera
Frank Barrera
  • 473 posts
Posted 22 April 2007 - 11:04 PM
hello everybody
thanks
Any edition of the American Cinematographer Manual will have a depth of field chart. Keep in mind that the format doesn't effect the depth of field of your lens. The format effects the field of view. Say a "normal" field of view is about 40 degrees. You would need a 35MM lens in the 35MM format; a 17MM in the S16 format; or a 12MM in the 2/3" format to get a 40 degree field of view. So if you are using a 12MM lens in the 2/3" format you will look up your f stop in the All Formats Depth of Field Table under 12MM.
#3 Patrick Lavalley
Patrick Lavalley
  • 91 posts
  • 2nd Assistant Camera
  • Portland, Oregon
Posted 23 April 2007 - 09:32 AM
The public library usually has a copy of the American Cinematographers manual, if you want to do it on the cheap, just photocopy what you need.
