Arri IIA Shutter
24 replies to this topic
#1 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 23 April 2007 - 06:45 AM
I just bought an Arri 35 IIA and need to identify the shutter angle. It should be 120 degree, but it could have been upgraded at some point to 180 degree. How do I tell the difference?
#2 Christian Appelt
Christian Appelt
  • 470 posts
Posted 23 April 2007 - 12:51 PM
Frank, all Arri 2A models had an 180 degree shutter. Only the Arri I+II had the smaller shutter opening.
You can make sure that your camera is a IIA by removing the small plastic cover over the claw drive - Arri II has a round disk, IIA and later models have a eccentric (heart-shaped) disk.
#3 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 23 April 2007 - 01:11 PM
Actually, the movement wasn't changed until the 2B.
#4 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 23 April 2007 - 02:38 PM
Christian is correct.
The 35II is frequently misidentified as the IIA.
Perhaps because the differences between the IIA and IIB are so minimal.
Another difference between the II and IIA is that the II has a single set of wings that open the mount blades on all three lens mounts, while the IIA and all later models have a set on each of the mounts.
#5 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 23 April 2007 - 02:56 PM
#6 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 23 April 2007 - 03:02 PM
Sorry Leo, but I'm standing my ground on this one. The difference between the II and IIA is the 180 degree shutter. The claw mechanism was changed on the 2B, and is identical on the 2C.
#7 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 23 April 2007 - 03:12 PM
I'm pretty sure this is a IIA because the serial number starts with Nr. I found a camera that is known to be a IIa that also has that prefix. Thanks for the info on the wings, this camera has them for each lens.
I am in question about the shutter angle because Visual Products says on their site that the Arri 35 IIA has a 120 degree shutter. I person I bought the camera from thought this camera has a 180 shutter, but wasn't sure. The mirror in this camera is a "butterfly" shape with four mirror faces. I should be able to measure the mirror and determine the angle, but I need the specs. I have had NO luck finding this information on the web. If someone has an Arri with the 180 degree shutter they could measure the widest part of the mirror and post it.
Because these cameras are upgraded and modified over the years, I don't want to assume anything.
#8 Christian Appelt
Christian Appelt
  • 470 posts
Posted 24 April 2007 - 01:35 PM
I have scanned an article taken from FILM TECHNIKUM, a German film technology paper, printed in June 1954, page 154:
The text is in German, I will translate a few passages (some people on this forum speak German, so they can correct my amateur translation if necessary):
"Image steadiness had not been sufficient for all applications of the Arriflex, a price that had to be paid for the comfort of reflex viewing. The engineering departement of Arnold & Richter, Munich, have tried to improve on this to encourage the use of Arriflex for a wider field of applications.
They have succeeded in this by creating both a new 180-degree mirror shutter and a new film transport/pulldown system. This has resulted in 50% more exposure time, excellent steadiness and absence of any excess vibration."
On the photo, you can see the then-new heart-shaped claw drive so familiar to us Arrificionados ;).
In another issue of FILM TECHNIKUM and the other trade paper KINOTECHNIK, there is an advertisement by Arri for "the new model IIA camera with improved 180-degree-shutter and superior steadiness". Could not scan that one because the bound volume is very brittle, I'll scan another one next time I have access to a single magazine.
There is definitely no difference between Arri IIA, B, and C regarding the claw mechanism. My IIA no. 3962 has 180 degrees too. In the past, some people have tried to resell ARRI II models as IIA, maybe this is where the myth came from... :)
Edited by Christian Appelt, 24 April 2007 - 01:39 PM.
#9 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 24 April 2007 - 01:40 PM
The 1953 edition of the AC handbook states that the Arriflex 35 Model 2 has a shutter angle of 120 degrees.
The 1956 edition states that the Arriflex 35 Model IIA has a shutter angle of 180 degrees.
Under TYPE OF DRIVE it is stated that the 2's "tachometer registers speeds to 40 frames per second with 30 V batteries". I've tried driving one with a 16V, it couldn't get past 8 or 12 fps. But a CP Xtal motor ran it at 24 fps.
The IIA has "Tachometer registers speeds to 50 frames per second with 16 V batteries."
Since the AC handbooks were printed while thus models were being manufactured I give them more credence than a contemporary web site which is 50 years after the fact.
Chek your tach and the number of lens locks on your camera to see if it's a 2 or a IIA.
#10 Christian Appelt
Christian Appelt
  • 470 posts
Posted 24 April 2007 - 01:47 PM
Just wanted to add that the article's headline says Arriflex with new Mirror Shutter
Note the picture, here you can see the then-new heart-shaped claw drive so familiar to us Arrificionados ;).
#11 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 24 April 2007 - 02:27 PM
Now were're getting somewhere. Christian, since you have an Arri IIA with the 180 shutter, could you measure the shutter opening (at widest point)? The opening is a different width for 120 than it is for 180 so if I have a measurement on a shutter that is a known opening, I can then measure mine and know what I have for sure. I'm getting great information here on early Arriflex models, but since the shutter opening controls exposer, it would be very expensive to ruin film guessing the shutter size wrong.
I suspect this camera has been modified over the years, so I just want a way to verify things.
#12 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 24 April 2007 - 03:17 PM
Since two different Arri techs I know claim otherwise, we're probably just going to go around in circles on this. One of them, at Cinematechnic, has a website which spells out the differences between the different models quite thoroughly. If you still think they've got it wrong, you should tell them.
#13 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 24 April 2007 - 05:18 PM
I never thought I would stir up this much disscusion of which camera has what mirror! Somehow I thought there would be a way to just look at the mirror and know what I have. Ha! Anyway, I guess I can always use measurements and math. Maybe I'll just shoot a little footage exposed for the 180 mirror and see if it comes out too dark.
Boy, it seems like there should be some way to look at the mirror and determine the shutter degrees.
#14 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 24 April 2007 - 06:03 PM
Welcome to Cinematography.com! I was just trying to help you identify the camera. I know Christian also means to be helpful, and we can respectfully disagree. You might find the Cinematechnic web site interesting, especially concerning the history of Arriflex cameras, and if you send Jorge an e-mail with any questions, he'll probably answer you within a couple of days.
#15 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 24 April 2007 - 09:20 PM
I went to cinematechnic.com (not my first time) to contact Jorge. To my surprize, he said he has not seen the Arri IIA. He also thought it would be either a 180 or 165 degree shutter. He has not heard of a 120 degree shutter. Probably didn't think of an older shutter from a 35II being a possibility -I'm sure he's a busy guy.
The camera looks to be built from other cameras. I ran some dummy film through it and it seems to work great. That's what I bought it for is having a camera that works (it has ugly paint). The two halves of the body look like they came from different cameras. There is a difference in the way they are painted. I think the camera was assembled then painted, but it easy to tell the two sides are different. The door I would guess came from still a different camera.
All this leaves still leaves me with the question: Which shutter does it have?
Edited by Frank Cook, 24 April 2007 - 09:21 PM.
#16 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 25 April 2007 - 01:52 PM
So Frank says that Jorge has never seen a IIA.
I don't have the AC Handbook Xeroxes with me today, but the descriptions of the the pulldowns for the 2 and IIA are different, with the IIA described as having a registration effect. This agrees with Christian's article.
As to why the principle differences between the IIA and IIB are an upgraded motor and the 480 magazine, you'll have to ask Arri. & that's from 50 years ago.
#17 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 25 April 2007 - 02:47 PM
All this establishes is that no one has ever sent him a 2A for repair. If you're convinced that Cinematechnic, which is an authorized Arri service center, is putting out misleading information on their website, then you should notify them.
#18 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 25 April 2007 - 03:12 PM
I have only the highest respect for a repairman that says he doesn't know (MUCH better than the guys that will lie and claim to be an expert). I think Jorge gave a good honest answer. Kudos to him. I was surprized that he has not worked on the Arri IIA, but I don't think he tried to mislead me, or give out bad information. Who knows, maybe I'll be able to sent the camera in to Cinematechnic for some upgrades, then Jorge will have his chance to look it over.
#19 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 25 April 2007 - 10:41 PM
Ah ha!!! I have it.
I was advise by Tobin that measuring is the only way to identify the shutter. Hmm. They reminded me the 180 degree shutter is half of the area of the shutter. So I looked at the camera and realized all I needed to do was compair the size of blades vs. the opneings. A 180 would have them both the same size. Mine has more mirror, so it is a 120 degree shutter. (There's too much difference to be a 165 degree shutter)
Thank guys!
Edited by Frank Cook, 25 April 2007 - 10:42 PM.
#20 Frank Cook
Frank Cook
  • 42 posts
  • Alaska
Posted 06 June 2007 - 03:09 AM
Up-date: The camera I have turned out to be an Arri Model 1. No wonder I could not find information on the specs that match the camera! I have not done a registration test, but it runs nice and smooth with dummy film, and will pull a full mag. The camera has all matching ID codes inside, even the motor (127).
