beaulieu R16 connections
#1 Stephan Schuh
Stephan Schuh
  • 14 posts
Posted 29 April 2007 - 02:53 PM
Hello!
I just bought a beaulieu R16 and want to hook it up to an external battery. I already found out that it is running on 7.2 volts or up to 8 volts. But I can´t find a description of the polarity of the three pins in the plug.
Is there also the same problem like with the 8mm Beaulieu, that the battery is providing two different voltages? I tried to power it with self built extrenal batteries and there was no way I could get it running because of this.
Thank you for your reply!
schuh
#2 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 29 April 2007 - 06:58 PM
Hi Stephan, pin#1 is ground/common. Pin#2 is hot/positive around 4volts. Pin3 is hot/positive around 8 volts. The pins are numbered. Good luck.
#3 Stephan Schuh
Stephan Schuh
  • 14 posts
Posted 01 May 2007 - 04:59 AM
Hi Bernie!
Thanks for your reply. Do you know what the 4 Volts are needed for? Can I feed the 8 Volts only and get the camera running anyway?
(I assume that the 8 Volts run the engine and the 4 Volts probably the lightmeter or auto iris/zoom control on the R16 automatic.)
With the Super8 Beaulieu that didn´t work, the 4 and 8 Volts also need to be "balanced" in some way. It didn´t work with just feeding 4 Volts to one cable and 8 to the other because the two voltages share the same ground.
It would be nice if I can use a simple 8 Volt Battery because I have some for my ARRI ST already.
Best regards from Cologne/Germany!
schuh
#4 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 01 May 2007 - 05:42 AM
Hi Stephan, If you are not using the meter, you are ok with the 8 volts. A lot of people prefer hand-held meters. They are more accurate than the camera's internal meter.
A common ground split- voltage battery is used, they have pancake cells and tap off midway up the cell-stack for the 4 volts.
But again, you simply need Pin#1 as groung and Pin#3 as 8 volts to run the camera. If that's not working, then it could be themotor, or the internal fuse, or even the main power transistor may be caput.
