What Lights Are These?
7 replies to this topic
#1 Matt Workman
Matt Workman
  • 421 posts
  • NYC
Posted 02 May 2007 - 12:28 PM
Hey,
I'm putting together a lighting kit for a small feature coming up and I am planning on using mainly small soft lights. There is a lot of small room dinner/tv scenes so I was thinking of getting a kit with the Chimera 20" China and the Pancake.
Shown here: What lights are they using and what kind of stand are they using?
http://www.filmtools...eralantern.html
I was thinking of mainly using the Mogul Light socket with practical bulbs like these:
What lighting fixture are they using in this photo also?
http://www.filmtools...hoba2532qu.html
Thanks for the help.
Cheers,
Matt :ph34r:
  • 20068 posts
Posted 02 May 2007 - 01:02 PM
http://www.filmtools.com/rps.html
"The RPS 250 Watt to 750 Watt Variable Quartz Light is a fully adjustable, 1-light kit with 6 foot stand with clamps. Switchable 1+2+3 bulb control gives you 250 watts, 500 watts or 750 watts with all 3 bulbs on."
The light in the Chimera may be a K5600 Joker Bug light:
http://www.k5600.com...ucts/index.html
#3 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 02 May 2007 - 03:41 PM
I use the 30" Chimera model and have a Mogul base like this one:
Base from B&H
I use a Matthews Junior Matth boom with a drop down pin, all on a rolling senior stand.
This is a pretty large setup so if you're working with 8' ceilings and a small room it might be too much. There are a couple of design issues with the setup. The socket doesn't hang from its center of gravity so the light has a tendency to swing one way or another, but you can control that by mounting the socket so it sits to the side of the drop down pin instead of the front or back. Another thing is it comes with a really short cord.
But despite the negatives it provides a really soft and controllable light source. And it's a pretty fast setup.
#4 Phil Gerke
Phil Gerke
  • 59 posts
  • Sound Department
Posted 02 May 2007 - 07:20 PM
I have not worked with those quartz lights. Is there any reason a normal dimmer would not work with them? I see the fixture that film tools sells, the one David pointed out. I assume the dimmer in that simply controls the voltage right?
Thought I'd ask before I get too excited, getting sick of photo floods.
Thanks!
#5 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 03 May 2007 - 05:48 PM
Yes, I use a dimmer with my setup.
#6 david west
david west
Posted 11 May 2007 - 01:36 AM
does your color temp change as you change brightness with your dimmer?
#7 Phil Gerke
Phil Gerke
  • 59 posts
  • Sound Department
Posted 16 May 2007 - 11:14 PM
Again, I have not worked with these, but I image if a voltage controller can be used as a dimmer than I would be willing to bet the usual temp change would occur.
#8 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 22 May 2007 - 04:26 PM
Yes it does.
