vivid colors
#1 Chris Dingley1
Chris Dingley1
  • 41 posts
Posted 03 May 2007 - 03:16 PM
Hi, I really enjoy DP's that shoot for vivid colors, movies like big fish, garden state among others.
What techniques with lighting, film stock, color correcton are done to achieve this.
#2 Nathan Milford
Nathan Milford
  • 692 posts
  • New York, NY
Posted 03 May 2007 - 03:45 PM
Shoot colorful things.
#3 David Mullen ASC
  • 20068 posts
Posted 03 May 2007 - 03:58 PM
"Garden State" was mostly shot on the Fuji 500D stock, which is not vivid at all.
"Big Fish" was shot on regular Kodak stocks and went through a D.I. to manipulate the colors, which were designed in the 50's era scheme of strong reds, etc., at least for the flashbacks.
There is a new Fuji Vivid 160T stock you should check out. Kodak Vision Premier is the most saturated print stock.
Overexposing negative a little helps give the image more snap, and thus more saturation. Polas help reduce glare, color enhancer filters can make reds pop.
A lot of this is art direction though.
#4 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 03 May 2007 - 04:24 PM
Hey, do you remember the pre-DI movie "Heathers"? I remember that created a bit of a stir because of its hyper-saturated look.
#5 Chris Dingley1
Chris Dingley1
  • 41 posts
Posted 03 May 2007 - 06:40 PM
See i understand that you can shoot interiors vivid by shooting colorfull things, but i will go ahead and assume that it is DI that mostly gives it the vivid for things like nature?
#6 David Mullen ASC
  • 20068 posts
Posted 03 May 2007 - 07:01 PM
There are limits to how saturated you can make the color with normal color negative processes -- you could use Ektachome 100D (5285) color reversal, which is more saturated, but also a lot more contrasty, plus it's more expensive, as is the E6 processing, unless you cross-process it into a negative, but then it gets a bit bizarre-looking.
Color is enhanced by frontal lighting, so shooting colorful objects in frontal sunlight would look the most saturated outdoors.
#7 Chris Dingley1
Chris Dingley1
  • 41 posts
Posted 03 May 2007 - 07:08 PM
thanks alot
