Exposure Compensation for White Promist
#1 Dan McCormick
Dan McCormick
  • 31 posts
Posted 03 May 2007 - 03:42 PM
Hi
Could someone tell me a good exposure compensation when using white promists 1, 2 and 3.
Dan McCormick
  • 20069 posts
Posted 03 May 2007 - 04:01 PM
There is none, although with the really heavy #3, if you get too much halation from a bright area, you may want to stop down a little to reduce it, or switch to the lighter grade.
ProMist diffusion does not increase overall brightness -- it causes bright areas to halate (glow) into darker areas.
#3 Vincent De Paula
Vincent De Paula
  • 52 posts
  • Vancouver / Los Angeles
Posted 08 May 2007 - 03:57 AM
Hey Dan,
There is no compensation but be aware of the strength of the filter. It can look awkard if too strong. If you are shooting on video the effect will be stronger than on film.
Also, on wider shots you'll be better off using a lighter one than in close ups.
It obviously depends on what you want to achieve with them.
Take care
