C Mount Anamorphic Lens
#1 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 04 May 2007 - 09:18 PM
Any one knows of c mount anamorphic lenses or if there is an adaptor from PL mount to C mount.
Thx, Chuck.
  • 20072 posts
Posted 04 May 2007 - 09:21 PM
"Chuck" you need to go to My Controls and change your Display Name to a real first and last name, as per the forum requirements listed when you registered.
Also, why is this posted in the Arri D20 subforum?
#3 Francis De Marco
Francis De Marco
Posted 28 June 2007 - 04:00 PM
Thx, Chuck.
Did you check with Century Optics, (now Schneider I beleive)? They may have PL/C mount adapters (www.centuryoptics.com)
#4 kevin jackman
kevin jackman
  • 350 posts
Posted 28 June 2007 - 04:16 PM
why post under here and what exactly are you trying to do?
#5 John Sprung
John Sprung
  • 4635 posts
Posted 29 June 2007 - 12:49 PM
C-mount was originally designed for 16mm when it was a home movie format. It consists of a simple screw thread, nominally 1" outside diameter, and 32 threads per inch. That's a National Fine standard, you can buy taps and dies for it from any machine shop supply place. The flange - focal distance for C-mount is 0.690", and most lenses will have threads extending about 0.150 - 0.160" deeper into the camera. That leaves you just over half an inch between the end of the one inch cylinder and the film. Most mounts for 35mm, to which the D-20 was dimensioned, are quite a bit deeper, typically near a couple inches. That makes the adapter the OP wants quite difficult to make. It's typically easier to adapt 35mm lenses to C-mount cameras. They're also sure to cover the whole 16mm frame.
#6 Chris Keth
Posted 16 July 2007 - 11:21 PM
Be careful if you make or rent an adapter. The weight of the adapter plus the average PL mount prime is probably too much for a C lens mount. A zoom certainly would be too much.
