I Need Battery Advice For My Arri-BLEQ =)
#1 Curtis Johnson
Curtis Johnson
  • 1 posts
Posted 08 May 2007 - 08:51 PM
Hello Friends,
I've Been Reading All Your Posts For Quite Sometime, But This Is My First Official Post =).
I Recently Acquired An Arri-BLEQ And I Need To Get A Battery For It.
Are There Any That You Would Recomend?
I Was Looking At The Bescor 12 Volt Battery Belt, Are These Any Good?
Also, I'm From Los Angeles So If You Know Of A Place Local That Sells Them, That Would Be Even Better.
Thanks So Much For Your Help Everyone,
~CJ
#2 Kenny N Suleimanagich
  • 902 posts
Posted 08 May 2007 - 09:38 PM
Sorry this isn't any help, but may I ask why You Always Use Capital Letters At The Beginning Of Every Word?
#3 Chris_Burket
Chris_Burket
  • 77 posts
Posted 08 May 2007 - 11:13 PM
If you have a 12 volt camera, the possibilities are endless. You could use a lot of different batteries. I depends on how you feel about weight, and how long you want the batteries to last. If you want to go with a cheap option, get a 12 volt lead acid battery, put a fuse and an XLR connector on it and drop it in some sort of container (pelican's are great). You could get a battery with anywhere from 4.5 amp/hours for $25 to one that has 30 amp/hours for $100+. Also remember that the more amp/hours, the heavier it is as well.
#4 Fran Kuhn
Fran Kuhn
  • 352 posts
Posted 09 May 2007 - 08:29 AM
Hello Friends,
~CJ
Hi Curtis,
Try Victory Cine Battery Corp. in Burbank area: http://victorycinevi...y.com/index.htm
Just be sure to get the proper voltage. I know many of the Arris have 8.3 volt motors, though some later models are 12 volt. Running 12 volts through the 8.3 motor may work for a while but this can damage the motor. In either case, Victory will be able to make the right battery for you.
Fran
#5 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 09 May 2007 - 08:34 AM
Hi Curtis,
Fran
Fran,
Have you dealt with them? Their web page is scary. Tons of typos, words left out. I thought, since they mention they just moved, that maybe they threw a page up in a hurry without having time to check everything. Then I read that they moved back in 2005. I hope their batteries are better than their web page.
-Tim
#6 Fran Kuhn
Fran Kuhn
  • 352 posts
Posted 09 May 2007 - 09:30 AM
Fran,
-Tim
Hi Tim,
I've had them build two belts for my Arri S/Bs, one 8.3 volt and on 12 volt (for use with a Tobin 12v motor). They did a really great job and I've never had any problems with the belts.
-Fran
