Hyperfocal distance
#1 Antonio Bunt
Antonio Bunt
  • 134 posts
Posted 09 May 2007 - 11:51 PM
My sight is going bad to the extent I need a cornea transplant but I need to make a film. Can I use hyperfocal distance to focus or I just better leave this career? How does hyperfocal distance work? Thanks!
#2 Mike Bove
Mike Bove
  • 14 posts
  • Chicago
Posted 10 May 2007 - 12:09 AM
Well I'm not sure about the career part per se, I'll leave that question to other, more experienced people. But to venture a guess if you have depth of field charts and a good AC and camera operator, I wouldn't see the need to change fields. Except if you were out to be a camera operator, that may not be your best bet. If you want to be an AC well, AC's don't need to look through the viewfinder so you should be okay.
The hyperfocal distance is the distance where, at a certain f-stop and with a certain focal length, you get the most depth of field possible, usually to infinity although there are some exceptions. A general rule of thumb is when at the HFD, 1/2 the distance from the HFD to infinity will be in focus. Something else to remember is that the HFD is not the figure you set your lens barrel to. HFD's corrospond to certain distances.
Hope this helps.
#3 David Mullen ASC
  • 20073 posts
Posted 10 May 2007 - 01:02 AM
Hyperfocal distance settings won't be a substitute for focusing a lens, but I'm not sure why you can't hire a focus puller.
#4 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 10 May 2007 - 01:55 AM
Is it both your eyes that are going bad? Nicola Pecorini only has one functioning eye, to name a DP/Operator with eyesight issues.
You can be a DP and go an entire shoot without looking through the eyepiece if you have video assist and a good operator with reliable AC's.
As far as hyperfocal distance...that's almost the same as Depth of Field which can always be calculated mathematically or assumed by consulting DoF charts. So long as your lens is accurate as evidenced by focus tests, and it's set for critical focus on your main subject, you should be fine. Otherwise, go Gillliam and use only wide-angle lenses where hyperfocal distance is almost always evidenced.
Edited by Jonathan Bowerbank, 10 May 2007 - 01:58 AM.
#5 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 10 May 2007 - 10:16 PM
At any given apature you have a depth of field. all within that depth of field will be "aceptably sharp" at least to the folks who calculated the depth of field tables..
If you take a small appature, like f-11 and set your lens so that the infinity mark is on the edge of the depth of field, the closet object that will be in focus whould be at half the distance you are focued at. To take a typical example, you may find that a 10 ft setting will put infinity at the f-11 mark on one side, and 5 ft at the mark on the other. SO everything from 5 feet out to infinity would be "in focus"
Problem is of course that often you _don't want_ everthing to be in focus, you want to direct the viewers eye. that is why you see folks squinting through those 85N9 filters so that they can open up the lens to get a small depth of field.
This is why the seting is often done by seting the lens scale insted of looking through the lens. The shot may have two or more Changes in focus as the action moves from forground to background.
