500, 1000, 2000fps
13 replies to this topic
#1 Dan Goldberg
Dan Goldberg
  • 121 posts
  • London, Ontario, Canada
Posted 11 May 2007 - 01:47 PM
Hey all,
This is likely a fairly straight-forward question, and although I'm not a beginning filmmaker per-say, I know little on the topic of "high-speed shooting".
I recently purchased a DVX100B and I think I am in love :rolleyes: . However, I noticed the capability of shooting 250, 500, 1000, and 2000 fps. I was wondering when you would use these high-speed framerates and what effect it gives. I understand the need for more light the faster the frame rate, but I am unsure of what each framerate's benefit is and what effect it could give.
Any help would be greatly appreciated. Thanks in advance! :)
Dan Goldberg..
#2 Chris Keth
Posted 11 May 2007 - 02:25 PM
Those aren't framerates. Those are shutter speeds.
The significance of framerate is in speed manipulation. Since everything is projected at 24fps in america, shooting at less than 24fps give you a fast-motion effect and shooting more than 24fps gives slow motion. 1000fps will stretch one second of real time into about 40 seconds of screen time.
Edited by Chris Keth, 11 May 2007 - 02:27 PM.
#3 Patrick McGowan
Patrick McGowan
  • 173 posts
  • P.A.
  • Brooklyn, NY
Posted 11 May 2007 - 02:36 PM
Where did it say fps on the camera? I am kind of confused by that question, sorry. From what I understand those are 1/500, 1/1000 etc. of a second not 1000 frames per second. So this would be comparable to the time that a film shutter would be open (depending on the shutter angle) rather than how many are exposed in a second...
right?
Edited by Patrick McGowan, 11 May 2007 - 02:38 PM.
#4 Dan Goldberg
Dan Goldberg
  • 121 posts
Posted 12 May 2007 - 06:37 PM
:unsure:
Yikes, I goofed.
I meant shutter speeds yes. I'ms orry if I confused people, I wasn't thinking straight :blink:
Thanks for the help, both of you.
#5 James Steven Beverly
  • 4199 posts
  • El Paso, Texas
Posted 13 May 2007 - 02:47 AM
They do shoot those kind of FPS for sientific research, specialty photograpy like the bullet spliting the playing card or going through the apple so they're not NESESSARILY shutter speeds. :D
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 13 May 2007 - 04:06 AM
I tested the Phantom HD last week, just pouring milk on cornflakes @1000 fps looks very cool! Changes in peoples faces as they talk is really weird.
Stephen
#7 Chris Keth
Posted 13 May 2007 - 03:24 PM
True, some camera can do that but a DVX is not that animal ;)
There's a prof here at RIT who's well known for special effects photography. He does a class every year where they do things like shoot a bullet hitting an apple, spliting a card, popping a balloon, et cetera. Very cool stuff. He invented an electronic shutter that works down to something like 1/100,000th of a second.
#8 Dan Goldberg
Dan Goldberg
  • 121 posts
Posted 14 May 2007 - 12:18 AM
So are those shutter speeds, 500, 1000, and 2000 specifically for slow motion effect? Or are there other effects or benefits of those speeds?
#9 Dory Breaux DP
Dory Breaux DP
  • 291 posts
  • Fort Bragg, CA
Posted 15 May 2007 - 09:33 PM
1/48 is the standard film shutter speed for 24 fps (realtime). On a video camera, you can set it higher for a smoother immage (less moion blurr, but I find motion blurr contributes to the film look) but ou will need to open the iris more.
#10 Chris Keth
Posted 15 May 2007 - 09:48 PM
Back up a second. A higher shutter speed will not make a smoother image. It will make a choppier-looking image. Motion blur is integral to a "smooth" image and is a big part of the look of film.
#11 Patrick McGowan
Patrick McGowan
  • 173 posts
  • P.A.
  • Brooklyn, NY
Posted 15 May 2007 - 10:05 PM
Yeah, because it simulates a shorter shutter opening time which cuts quite a bit of light and increases strobing. The strobing is what looks choppy, but the number of shutter intervals makes the image look super sharp as it captures the motion of an object very clearly.
#12 Chaz Buhrmann
Chaz Buhrmann
  • 19 posts
  • Australia
Posted 16 May 2007 - 09:00 PM
I use 1/50th(PAL) for normal shooting and 1/1000th for slow motion(depending on light). If you run a test, you'll see shooting at a much higher shutter speed will give you far better slow motion. I'm not sure of the other uses for such high shutter speeds.
#13 Dan Goldberg
Dan Goldberg
  • 121 posts
Posted 16 May 2007 - 10:35 PM
i see. thanks so much for the help ;)
any other uses for higher shutter speeds? other than good slow motion capabilities? just wondering :P
#14 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 16 May 2007 - 11:29 PM
"any other uses for higher shutter speeds?"
Producing sharper looking footage of fast moving subjects like motor sports. There would be less blur. However, as others have said, you do run the risk of ending up with footage that will not look entirely smooth with regular frame rate shooting - 25fps / 30fps etc.
