Correct Lens…?
9 replies to this topic
#1 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 13 May 2007 - 10:35 PM
I am working with a camera that has a 16mm x 12mm CMOS chip; this is bigger than a typical 2/3" sensor and smaller than 35mm film image area (~24mm x 18mm). Can someone recommend an appropriate lens to use with this type of a camera?
#2 Chris Keth
Posted 14 May 2007 - 09:24 AM
Well, you'll ahve to cover the format so probably 35mm format lenses are going to be the right tool. What lens mount are you working with?
#3 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 14 May 2007 - 10:47 AM
It has an F-mount... I can get them to build me a custom PL mount. Do you think the Zeiss F mount photo lenses have the same optics / quality as other PL mount lenses?
#4 Chris Keth
Posted 14 May 2007 - 11:49 AM
They should, more or less. They'll be a pain to pull focus with, though. Most photo lenses only have 1/4-1/2 of a rotation for the entire focus range.
#5 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 14 May 2007 - 12:55 PM
This might be a good option...
http://www.zgc.com/z...71?OpenDocument
#6 Adam Paul
Adam Paul
  • 303 posts
  • Here and now
Posted 15 May 2007 - 03:56 PM
What Digital Cine camera has a 1" sensor?
#7 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 16 May 2007 - 02:09 PM
A 1" sensor would be 9x12mm with a 16mm diagonal.
12x16mm sensor would be a 1.25" tube, which used to be a common broadcast format.
Usually had plumbicon tubes.
#8 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 16 May 2007 - 10:02 PM
I am using a custom built chip/camera; actually it is not a full 1inch chip (close to 1inch).
Below are the specs:
Array Format: 2,400H x 1,800V
Sensor Imaging Area (approximately): 16mm H x 12mm V -Diagonal 20mm
#9 Adam Paul
Adam Paul
  • 303 posts
  • Here and now
Posted 28 May 2007 - 06:46 PM
Custom built?
Is it one of them machine vision/security camera projects?
What do you record to and what format?
#10 Chuck Toeti
Chuck Toeti
  • 19 posts
  • USA
Posted 06 August 2007 - 12:12 AM
Custom built?
Sorry for the delayed reply, i was out of the country.... Yes it is form a machine vision project, it has a Camera Link output.
