Does push processing only raise contrast in 5218?
#1 Ben Weinstein
Ben Weinstein
  • 8 posts
Posted 14 May 2007 - 12:24 AM
In a discussion of push processing with a German DoP friend of mine, he mentioned that some German cinemtographers had done extensive tests pushing 5218, and found that it did not lead to a brighter image, only a more contrasty one, (a darker black) resulting in a perception of added brightness, but no real benefit. Any one ever hear of such a study, or take part in it?
B
Posted 14 May 2007 - 01:18 AM
Push-processing increases the density of the negative, so if you exposed normally and then push-processed, you'd get more density than normal as a result. But usually push-processing is combined with underexposure to end up with normal density. So the image, if underexposed by one stop, and then pushed one stop, wouldn't end up "brighter", it should end up normal in brightness, more or less.
But the result would also be increased contrast and more graininess, plus some color shifting and perhaps color in the blacks.
Pushing doesn't increase sensitivity -- it can only take what was captured by the emulsion and increase its density after processing.
#3 Ben Weinstein
Ben Weinstein
  • 8 posts
Posted 14 May 2007 - 01:48 AM
Well put, thank you.
What about Fuji 500T Eterna pushed one vs. 5218 pushed one? For grain? DOe one handle a push better?
b
#4 David Mullen ASC
Posted 14 May 2007 - 02:39 AM
They both handle a one-stop push well -- I've done it to both stocks on different features. However, I haven't done a side-by-side test.
#5 william koon
william koon
  • 82 posts
Posted 18 May 2007 - 09:35 AM
David, What happens if I overexpose the stock by 1 stop and pull 1 stop in processing? Does it mean it decreases the density and lessen contrast? Thanks
#6 David Mullen ASC
Posted 18 May 2007 - 10:29 AM
The net density is normal because you would normally have gotten extra density from the overexposing, but you pulled the processing by the same amount to compensate and thus ended up back to normal density. Pull processing reduces density.
However, you'd end up with less grain, less contrast, softer blacks and colors.
#7 william koon
william koon
  • 82 posts
Posted 19 May 2007 - 10:15 AM
thanks David
Regards
