Konvas 1M, 2 perf and KS perforations
#1 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 16 May 2007 - 11:35 PM
Hi all,
I have a konvas 1m that I only bought to be able to use normal still film (in bulk loads) to shoot. I am totally retarded regarding 35mm. So my questions are:
1 - does a camera converted to 2 perf spend less film per minute?
2. Is it possible to convert a konvas 1m with rheostat motor to 2 perf?
3. Can I still use film with KS perf after it's converted?
Many many thanks!
richardson
#2 Christian Appelt
Christian Appelt
  • 470 posts
Posted 24 May 2007 - 11:47 AM
Yes, it runs slower because the same length of film will carry twice as much 2-perf images compared to 4-perf.
It may be possible, but expensive because the Konvas movement needs much more machining than let's say with an Arriflex IIC that could be changed to Techniscope by exchanging a few parts.
Solid Entertainment (www.solidentertainment.se) does have Konvas 2M cameras converted to 2-perf and may advise you on possible conversions, but expect it to be expensive. Personally, I do not think it makes sense for an older 1M camera.
Remember that for 2-perf you need excellent lens performance because the image will be magnified more than with 4-perf, and I doubt that all older OCT-18 lenses will do that job. With a 2M converted to PL-mount, you have access to a variety of high quality glass.
The KS perf is larger than the BH negative holes, so it should work. But talk to someone who knows the conversion stuff.
Look here:
http://www.arandafil...ages/page7.html
Edited by Christian Appelt, 24 May 2007 - 11:48 AM.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 24 May 2007 - 12:17 PM
Hi all,
Many many thanks!
richardson
Most Konvas cameras are not pin registered, so the shape of the perf does not matter.
Stephen
