Overexposure inside to outside effect
#1 David Tanner
David Tanner
  • 1 posts
Posted 17 May 2007 - 09:08 AM
Hi
Im producing a short on film (Kodak vision2 250D Color Negative Film 5205/7205) and 1st time director rather ambitiously wants inside/outside transition shots to burn out/black out respectively before adjusting (giving a burning apocalyptic heat effect). Thought id get some professional advice on creating this effect and any advice on useful equipment.
#2 Hal Smith
Hal Smith
  • 2280 posts
  • OKC area
Posted 17 May 2007 - 10:10 AM
Use an aperture pull. If either the highlights or blacks (or both) are blown and/or crushed past the film's latitude, there won't be any image to work with in post. The equipment you need is a good 1st AC.
If there's a pan involved you could use a gag I used once where the sunlit part of the pan was behind a 5X6 ND6 filter on a C-stand. When I panned to the sun side, I automatically lost two stops behind the ND.
(I used some black wrap to make a light shield to flag reflections off the back of the filter.)
