Angi 9.5 - 95mm depth chart and field sizes wanted
#1 Michael Carter
Michael Carter
Posted 24 May 2007 - 01:02 PM
My Angi. 9.5 - 95mm lens has had the dog leg side reflex view finder removed and the hole plugged up with epoxy. Even so, it works just fine. I really like the 9.5mm wide angle.
It would help me save a lot of time if I knew the field sizes at different mm settings and also the depth of field at different distances and light settings.
Has a chart for that lens ever been published?
Michael Carter
#2 Brian Drysdale
  • 5196 posts
Posted 24 May 2007 - 02:41 PM
There wouldn't be any DOF charts for this particular lens, only the general 16mm DOF charts found in say the American Cinematographer Manual. The first time I can recall charts for particular lenses is when the Zeiss Super Speed Distagons came out.
Because this lens breaths when focusing the angle of view will change depending on how close your focusing the lens.
You can calculate both here:
http://www.panavisio...base.asp?cat=13
DOF tables here:
http://www.dofmaster.com/doftable.html
#3 Michael Carter
Michael Carter
Posted 25 May 2007 - 06:02 PM
DOF tables here:
Thank you, I think I can get one of them to work
