Tungsten and Fluorescent
#1 Matt Bizer
Matt Bizer
  • 52 posts
  • Albuquerque, New Mexico
Posted 24 May 2007 - 05:36 PM
Ok,
I am lighting a large space with very even light. the room has lots of Fluorescent light fixtures and the budget is only leaving room for a reasonable tungsten package or a kino.
What I am asking is if I am using soft white bulbs and controlling the florescent lights with duvi and such would it be better to correct the fluorescents or should I correct the tungsten kit with green?
(note - there are around 25 fluorescent fixtures.. )
thanks all
Matt
shooting on kodak 16mm 500T 7218
#2 timHealy
timHealy
  • 1262 posts
Posted 24 May 2007 - 05:45 PM
It would be very easy to add green to your tungsten light(s?) to match the flo's and time it all out during printing/transfer or you could do it at the lens as well with the appropriate magenta CC.
Does this room have any windows though?
Tim
Edited by timHealy, 24 May 2007 - 05:46 PM.
#3 Matt Bizer
Matt Bizer
  • 52 posts
Posted 25 May 2007 - 03:30 PM
That is an issue I hit. it does have 2 windows.
Tim
#4 chris kempinski
chris kempinski
  • 75 posts
Posted 26 May 2007 - 03:09 PM
most industrial lights are cool whites. a quick run up a ladder for a visual will let you know the type of bulb and, would give you an idea of what temperature you need to ballance to.
secondly about the windows, my suggestion would be to meet in the middle of the window and the flouros.
the window will be around 6000 degrees K and the flouros around 4000. so, I would suggest warming some blue tubed
kinos (so you get more output as blue gel takes away more light) with half straw. Again, I would use staw because there is a
natural green in the gel already.
The great thing about the 7218 is that the green spike is very minimal and the straw should balance out just fine in post.
thems my two cents.
good luck
Chris
Edited by chris kempinski, 26 May 2007 - 03:10 PM.
