K3 Load Problem (vid)
11 replies to this topic
#1 Dan Liffick
Dan Liffick
  • 8 posts
Posted 26 May 2007 - 12:58 PM
Hey everyone,
I've been trying to get my K3 up and running. The problem that I'm facing is I'm missing the film guide and often the film will not run properly threw my K3. Since I'm extremely new to film I thought I would make a DV of what I'm doing. Can someone please give me some pointers? Am I doing this correctly? Thanks again for all your help.
My 'How Do' video
I can't embed.. sorry.
#2 Eric Dinger
Eric Dinger
  • 52 posts
Posted 26 May 2007 - 01:15 PM
You aren't forming loops. There are some photos of a K3 being loaded at http://www.geocities...film-manual.htm , thought that one has the film guides, just make the film loops (the part of the film that runs around the guides) about the size they are in the photo.
It also looks like your using 2r (2 perf) film, and you have the film coming off the reel in the wrong place, it should follow the arrow painted on the bottom of the film chamber.
Edited by Eric Dinger, 26 May 2007 - 01:17 PM.
#3 adam schutzman
adam schutzman
  • 11 posts
Posted 28 May 2007 - 03:35 PM
man, it would be great if someone could post a video on youtube about how to properly load a K-3! any takers?
~adam
#4 Robert Glenn
Robert Glenn
  • 247 posts
Posted 28 May 2007 - 09:28 PM
I unlatch the spring pins that set those guide rails... then i pull the triggler a little to let it run through.. then form the loops.. forgot the # of sprockets above and below.. just follow the diagram. I had to sortof of push the film so it catches on the sprockets.. anyhow run it until the sprockets are correctly running into the holels and then put the plate back on and run it
#5 Mike Rizos
Mike Rizos
  • 330 posts
Posted 28 May 2007 - 10:12 PM
How'bout a new subforum called: "K3 loading problems".
#6 Dan Liffick
Dan Liffick
  • 8 posts
Posted 29 May 2007 - 11:13 AM
When I run the camera the loops go away, and it makes my film gate bounce around like crazy. Is this supposed to happen?
#7 Dan Liffick
Dan Liffick
  • 8 posts
Posted 29 May 2007 - 11:14 AM
adam- I would make a vid on the correct way, but I haven't figured it out yet. =)
#8 Mark Dunn
Mark Dunn
  • 2660 posts
Posted 29 May 2007 - 11:58 AM
You've got the spool the wrong way round. The film should come of the bottom of the spool, to the right.
Hope that helps.
#9 Mark Dunn
Mark Dunn
  • 2660 posts
Posted 29 May 2007 - 12:00 PM
It's not there yet, they have to process the film, ha ha.
And you don't have to load that fast, I was just trying to keep the file size down.
#10 Dan Liffick
Dan Liffick
  • 8 posts
Posted 29 May 2007 - 01:52 PM
Thank you Mark!, and everyone else for their help.
my K3 is now ready to kick some A!
#11 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 29 May 2007 - 09:06 PM
where all this 2r film coming from ? you could start a K3 loading club :huh:
#12 Mark Dunn
Mark Dunn
  • 2660 posts
Posted 30 May 2007 - 04:53 AM
It's old VNF left over from when I did high-speed cine for the military. High-speed kit is all double-perf. Single-perf would tear at 200mph.
But there hasn't been a double sprocket in an ordinary 16mm. camera for decades, so I'm told. The K3 has a single row of teeth and will take single-perf just fine.
