EASTMAN Double-X 7222
#1 Merlyn Haycraft
Merlyn Haycraft
  • 17 posts
Posted 27 May 2007 - 08:39 PM
Hi!
I am a week away from shooting a Super 16MM film and I am still procrastinating as to film stock. The film is shot all at night and the director wants black and white. However I am worried that Double-X is not fast enough.
I have thought about pushing it two stops but having seen it normally, it already looks grainy as can be, and I don't want too much of that effect!
So my dilemma is, do I stick with the Double-X and push it two stops, or film in 500T and go to black and white in the Telecine!?
Any insight would be much appreciated, and also as to which colour film stock to go for. I'd like a fairly sharp image with high contrast.
Thanks! :) :)
#2 Dan Goulder
Dan Goulder
  • 1259 posts
Posted 27 May 2007 - 09:01 PM
As much as I prefer using black and white negative for a b & w finish, if it looks like you're going to be two stops short, it would probably be best to use 500T color negative for this particular shoot.
#3 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 27 May 2007 - 11:57 PM
You could give the N74 Orwo a go?!
http://www.filmotec....4_e/n_74_e.html
that is iso 400
And quite pretty
cheers
richardson
Hi!
Thanks! :) :)
#4 Merlyn Haycraft
Merlyn Haycraft
  • 17 posts
Posted 28 May 2007 - 02:52 AM
Thank you both. I'll take both into consideration
#5 Patrick Cooper
Patrick Cooper
  • 908 posts
Posted 28 May 2007 - 03:28 AM
"I'd like a fairly sharp image with high contrast."
Bear in mind that fast films are usually lower in contrast. However, pushing any film will increase the contrast and this can make the images appear slightly sharper than they really are. Though there is also an increase in grain.
Edited by Patrick Cooper, 28 May 2007 - 03:29 AM.
#6 Merlyn Haycraft
Merlyn Haycraft
  • 17 posts
Posted 28 May 2007 - 07:06 AM
One more question concerning the tele cine. How exactly does it work, the process I mean? Does the telecine supervisor simply completely desaturate the image or should I be asking for something else?
#7 David Mullen ASC
Posted 28 May 2007 - 10:55 AM
They will lay down a b&w signal to tape -- the only twist is whether you want to play with the contrast while the image is in color first before converting it to b&w, because doing this gives you more control. It's a little like using color filters in b&w photography. If you correct the image in color first, you can darken a blue sky separately than a face, let's say, before you switch it to b&w. Less of an issue for interior photography.
