where to get gels
#1 jonathan grant
jonathan grant
  • 15 posts
Posted 29 May 2007 - 08:56 PM
Is there a place to get cto and ctb gels online? How much do they typically cost. I found one set online for over 100 dollars. That can't be right, I've purchased gels before and they were less than 10 dollars (from a theatre supply store)
#2 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 29 May 2007 - 09:02 PM
$100 a roll sounds like a good price actually. It should be around $7 - $10 a sheet.
www.studiodepot.com
www.filmtools.com
Are places that sell gel online.
#3 Mike Williamson
Mike Williamson
  • 534 posts
Posted 29 May 2007 - 10:02 PM
I'm a fan of the Expendables Recycler, they're hawking partial rolls left over from larger productions, check out www.expendablesrecycler.com. They've got the best prices I've found, somewhere around 1/2 of what gels cost new.
#4 jonathan grant
jonathan grant
  • 15 posts
Posted 29 May 2007 - 11:09 PM
For the record, there's a place where you can get them for under 3 dollars a sheet.
http://www.lightinge...rrection/Detail
If I had to get 3 of the CTOs and 3 of the CTBs which should I get? Which would I end up using most of the time? the 1/4, 1/2 and full?
#5 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 29 May 2007 - 11:22 PM
Those sheets are smaller (12x10), the ones I am talking about (the standard size I have always seen) are 21x24.
#6 Brian Drysdale
  • 5196 posts
Posted 30 May 2007 - 04:43 AM
Personally, the Full CTB and the 1/4 CTO tend to be the ones that I use the most when using tungsten lights. However, I always take the full range.
You can always double up on the 1/2 CTB gels if you can only afford one grade.
#7 JD Hartman
JD Hartman
  • 1764 posts
  • Edison, N.J. U.S.A.
Posted 31 May 2007 - 08:55 AM
I'd lean toward rolls or sheets of just 1/4 and 1/2 of CTB and CTO. You can have the full range just by doubling up the gels. Sme DPs prefer straw instead of CTO. You'll also need ND and some diffusion as well. B&H Photo in NYC is also another online source for sheets.
Edited by JD Hartman, 31 May 2007 - 08:56 AM.
