rain on window
7 replies to this topic
#1 Travis Cline
Travis Cline
  • 143 posts
Posted 31 May 2007 - 01:43 AM
I shot some tests tonight for a film I am shooting soon and I ran into more trouble than I bargained for. There are a couple of scenes in the film where we would like to have the shadow of rain drops on a window cast onto our talent. Very Conrad Hall-esque. In Cold Blood and the such. I tried using a fairly hard light, a Source 4 ellipsoidal with a 19 degree lense, through hampshire and put the "rain" on the diffusion, but that didn't work too well. Then I tried the same light into a mirror and put the "rain" onto the mirror. What proved difficult though was to get a well defined rain drop to move across someone's face unless they were extremely close to the mirror. Obviously I want to get the light as hard as possible, but aside from that, any suggestions? How to apply the rain? What to shoot through? Has anyone tried this, because if you haven't, believe me its harder than it seems. Thanks gents.
Travis
Edited by Travis Cline, 31 May 2007 - 01:44 AM.
#2 Jonathan Bowerbank
Jonathan Bowerbank
  • 2815 posts
Posted 31 May 2007 - 02:19 AM
I should think an open face light, undiffused, pointed through a pane of glass with water dripping down should do the trick.
You'll have to get the light relatively far from the glass as what you're trying to do is get that light to hit the rain drops at a point where the lights spread & falloff isn't so drastic and thus creates acute shadows on your actor's face.
#3 David Mullen ASC
Posted 31 May 2007 - 02:21 AM
Hall had a fan blowing heavy mist/rain onto the window that then collected and dribbled down the glass of the window. Then he had a very sharp light source and the actor standing close to the window. You want the rain droplets to be as close to the actor as possible and the light source to be as sharp and far away as possible.
#4 Gabriel Rochette
Gabriel Rochette
  • 26 posts
  • Québec, Canada
Posted 29 September 2007 - 06:42 PM
In low budget production witout weeks of test ...trial and error it,s a problem...BUT
My trick is to put a magnificion glass (kind a magnifificion glass for retro projector system) between windows and actor. It,s verry good for sure but you have to find 2 of them cause the rain will be inverse if you use only one.. Conclusion... 2 magnifying glass ..and ...thats it...
Gabriel
Québec
Canada
#5 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 30 September 2007 - 06:32 PM
The Hampshire is what killed the effect -- that diffuses the light. Also, the optics of source 4's are designed to focus a sharp shadow of the slide that's inside the unit, not focus shadows from subjects outside. With enough distance you can focus a sharp shadow from subjects in front of a Source 4, but then you could do that with other units as well.
#6 Chad Stockfleth
Chad Stockfleth
  • 622 posts
  • Louisville, KY
Posted 30 September 2007 - 07:53 PM
This might sound stupid, but I've done it before and it works pretty well, is a hard light shone through glass like everyone's said, and then use a little plastic squirt gun to spray onto the top of the glass, letting it drip down. Makes nice rolling streaks.
Nash is right, lose the Hampshire.
#7 drew_town
drew_town
  • 383 posts
  • Southeast US
Posted 01 October 2007 - 07:24 PM
There's a BTS shot of Donald McAlpine's setup in Romeo + Juliet on the DVD with this effect. If I remember right, he uses a sheet of Plexiglas with a wooden frame at a 45-degree angle and pours water down it. It's lit from behind. He goes into detail on the shot in the commentary. You might want to check it out.
#8 Bobby Shore
Bobby Shore
  • 95 posts
  • Los Angeles / Montreal
Posted 02 October 2007 - 08:47 PM
go open eye on a fresnel unit... that'll give you some nice, hard shadows.
Bobby Shore
DP
LA/Montreal
