angenieux retrofocus 6.5 lens?
#1 ishan vernallis
ishan vernallis
  • 48 posts
Posted 31 May 2007 - 07:10 PM
quick question-
does the angenieux 6.5mm retrofocus
work on 16mm or is it a 8mm lens...
any possibility that it might work for super16?
thanks!
#2 Charlie Peich
Charlie Peich
  • 247 posts
  • Chicago
Posted 02 June 2007 - 12:27 PM
quick question-
thanks!
I believe that that lens was designed for Regular 8 or "Double 8" cameras that had interchangeable D mount lenses. D mount has smaller diameter threads at 0.625 inch vs. C mount at 1.000 inch. You would have to make D to C mount adaptor ring, or would that be a C to D mount step down adaptor? The flange distance is shorter for D mount lenses at 0.484 inch vs. 0.690 inch for C mount lenses, so that would also be a problem for mounting on a C mount camera.
I doubt the lens would cover a standard 16mm frame completely.
You want to find the angenieux 5.9mm lens which was made for 16mm and costs more than the 6.5mm lens. I know there is a angenieux 6.5mm on eBay now, but they have it listed as a C mount. Ask them to measure the thread diameter for you before you bid on it.
#3 ishan vernallis
ishan vernallis
  • 48 posts
Posted 02 June 2007 - 06:07 PM
yes-
they wrongly listed it as c mount and as being for h16 cameras.
I've informed them of the misprint.
thanks for the info.
