Hand crank 35mm "Man on fire" look
16 replies to this topic
#1 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 02 June 2007 - 06:45 AM
Just did some shooting with an Arri 3 that had its motor removed and modified for hand cranking like the look in "man on fire". Unfortunately the gear ratio used made turning the handle fast enoungh to reach 25fps near impossible so I ended up using an electric drill attatched to the drive shaft and by altering the speeds forward and reverse I was able to get some amazing footage of our hero bashing up a victum who was tied to a chair. When I get the DI done ill get some QT clips to show.
Cheers G.
#2 John Sprung
John Sprung
  • 4635 posts
Posted 04 June 2007 - 03:38 PM
The informal standard back in the early silent days was 8 frames per turn of the crank. That's quite comfortable at 16 - 18 fps, and somewhat difficult to get up to 24 - 25.
#3 Kenny N Suleimanagich
  • 902 posts
Posted 04 June 2007 - 09:13 PM
I'm sure I speak for many when I say you should put up some pics/screenshots. I'd love to see what the powerdrill setup looked like.
#4 Phil Savoie
Phil Savoie
  • 94 posts
  • Montana / Wales
Posted 04 June 2007 - 11:12 PM
Arri Media in London had a 3C fitted with a hand crank, I was told it saw a good bit of action. I'm not sure of the gearing ratio or set-up. As it was only a few years back I'd bet they still have it - both Andy Subratte or John Duclos are good chaps, it may be useful to have a chat with them for operating tips.
#5 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 10 June 2007 - 02:44 AM
Cheers G.
Heres some stills from the shoot, ill get some footage soon after the 2K divinci grade. The drill is attached to a cog that has a rubber belt to the main mechanism that the motor was connected to.
Cheers G.
#6 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 23 June 2007 - 04:55 AM
Heres a link to some footage I shot with the Arri 35-3 with the handcrank option. This was removed and a standard electric drill was attached and run at various speeds 0-70FPS to create this effect. Note: No grading or sound post done.
Cheers
http://web.mac.com/c.../Handcrank.html
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 23 June 2007 - 07:01 AM
handcrank.jpg Hi,
It's very easy to hand crank a Mitchell GC, hand cranks were standard equipment to use when the battery was flat.
Stephen
#8 Adam Butterworth
Adam Butterworth
  • 21 posts
Posted 23 June 2007 - 09:12 AM
sweet looking stuff
#9 Kieran Scannell
Kieran Scannell
  • 339 posts
  • Netherlands/Ireland
Posted 23 June 2007 - 11:39 AM
Great look for the scene! was it all hand cranked? or spliced into the master shot?
Kieran.
#10 Olex Kalynychenko
Olex Kalynychenko
  • 868 posts
  • Dnepropetrovsk, Ukraine
Posted 23 June 2007 - 01:00 PM
If you need hand crank 35 mm cine camera, i can recommend russian Konvas-1 ( KSR-1M ) camera.
Konvas-1 can have a few versions of drives, this can be electrical motor with rheostat speed control,
hand crank with speeds up to 32 fps, hand crank for single shooting and rare, clock spring motor.
The design of Konvas-1 included of mechanical devices for control of speed.
This is device use for control of speed with all type of drivers.
This is inertia brake and you can adjust of volume of speed, or, if you need, you can disconnect of speed control.
If you modify of cine camera on the hand crank version, you not need forget about mechanical speed stabilization system.
#11 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 23 June 2007 - 08:08 PM
Kieran.
All hand cranked, each shot/setup is straight from the camera no effects added.
Cheers
#12 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 23 June 2007 - 08:10 PM
sweet looking stuff
Thanks, amazing what you get straight out of the box with handcrank.
#13 thomas-english
thomas-english
  • 99 posts
  • Steadicam Operator
Posted 24 June 2007 - 07:33 AM
could I achieve the same look with my plugin varispeed unit on my arri sr2? Are you just correcting the over exposure and under exposure in TK with dynamics?
#14 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 24 June 2007 - 05:51 PM
The problem (in my opinion) with using a drill instead of actually cranking is that you don't get the exposure and speed shifts you get when hand cranking. Don't get me wrong, the stuff you shot looks very nice, but it doesn't have the classic hand crank look. I understand why you used the drill since I've done a bit of hand cranking myself. 24fps is quite hard to achieve with a hand crank without having a very sore arm.
#15 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 27 June 2007 - 03:43 AM
It was possible to vary the speed easily just by grabbing onto the drill head and slowing it down and then giving it a quick burst again to ramp into slowmo.
#16 Brad Grimmett
Brad Grimmett
  • 2660 posts
Posted 27 June 2007 - 03:57 AM
You know, after I made my post I thought just that. But did you do that much? The motion and exposure just seemed more consistent than that.
#17 Glenn Hanns
Glenn Hanns
  • 160 posts
Posted 28 June 2007 - 08:31 PM
The director did want some parts to be consistent, so I had someone yelling out the frame rates from the LED readout. I could keep it at a certain speed if I wanted, One jib shot was done on an LT just to make it easier.
