quieting an ebm
9 replies to this topic
#1 Brian Woods
Brian Woods
  • 14 posts
Posted 02 June 2007 - 08:25 PM
query: has anyone ever quieted a bolex ebm enough to be used as a non-problematic sync-sound camera?
basically, i'm in a situation where i could invest money into buying a blimp or barney for my ebm and mag OR sell the entire thing and get an NPR or an aaton. what would you do?
i was just curious if anyone on here makes narrative sync-sound films with an ebm? how well does the barney suppress the sound?
#2 Tim Carroll
Tim Carroll
  • 2168 posts
  • Chicago, Illinois
Posted 02 June 2007 - 08:55 PM
Brian,
Search the archives, this has been covered quite a number of times.
Simple answer, the EBM is not a sync sound camera. Tried numerous barneys and even tried to make a home made blimp for one years ago. Did not turn out well. It is just too noisy.
If you can sell the whole package and get an NPR or Aaton, and you want to make sync sound films, I would suggest going that direction. The EBM will always be a bad compromise for sync sound filming.
-Tim
#3 seth christian
seth christian
  • 189 posts
  • Nashville, TN. USA
Posted 03 June 2007 - 12:35 AM
i actually just shot a short with my EBM and I had remarkable turnout on this project.
as long as you are using boom mics and not some omni or super cardiod or anything,
you'll be amazed of the results.
my barney is the original barney made for EBM's. (guy at cameraspro.com makes them
by the way) and then I also lined the inside of that barney with rabbit fur...yes...
believe it or not...rabbit furs. so i tried it and its awesome!
there was a study done in germany years ago and they found that the best way to
dampen sound in such case as a film camera is the microfibral hairs and many thin
coats of rabbit fur worked 5 times better than any one large cotton filled, insulation stuffed,
downfeather, canvas lined,......whatever.
So....good boom mics + a barney from guy + 2 thin layers of rabbit furs = surprising results.
However, Tim is right about one thing...if you dont want to deal with this hassle....
NPR or Aaton is much quieter.
Edited by seth christian, 03 June 2007 - 12:36 AM.
#4 kevin jackman
kevin jackman
  • 350 posts
Posted 03 June 2007 - 11:54 AM
so any type of animal fur?
i took a feather duvet on an ebm with mag, wrapped it once and the thing was almost totally quiet.i figured some mods to this idea just might work.
#5 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 03 June 2007 - 07:33 PM
have you guys heard of strasonic foam? very good for sound isolation.
#6 kevin jackman
kevin jackman
  • 350 posts
Posted 03 June 2007 - 09:57 PM
#7 kevin jackman
kevin jackman
  • 350 posts
Posted 03 June 2007 - 09:58 PM
theres also the rubbery material thats used for sound deadening. its not too thick, a bit heavy but it sure cuts sound
#8 Marty Hamrick
Marty Hamrick
  • 543 posts
  • Oshawa, Ontario
Posted 04 June 2007 - 11:00 PM
As I recall,we did OK with Turkish towells,but we never attempted to shoot in a studio with one.Usually we opted for renting an ACL or NPR or Arri BL.
#9 seth christian
seth christian
  • 189 posts
Posted 07 June 2007 - 01:25 PM
I dont know about any fur....i suppose anything in this nature is experimental...all i know is rabbit fur
was found to work the best for the german testing because its so fine (guy at cameraspro agreed that
a few layers of thin fur brings better results than one big fat piece) and the two benefits of using
rabbit anyway..is that its thin so you're not packing on too much bulk around your camera....and two,
rabbit fur is CHEAP!!!
#10 Richardson Leao
Richardson Leao
  • 363 posts
  • Stockholm, Sweden
Posted 12 June 2007 - 09:29 PM
I am sure though that the rabbit does not see any benefit on it...
The strasonic foam was used on a blimp for a konvas (or maybe a kinor) on a forum. It's a foam specially made for acoustical isolation. I got a sheet and it seems a very good isolator.
