Camflex CM1
#1 Ernest Cahl
Ernest Cahl
  • 23 posts
Posted 05 June 2007 - 04:05 AM
Hello ,
i am new on this forum .
i ll be shooting a music Clip in two weeks in Italy . i bought recently a Camflex CM1 ( not CM3) , 16 and 35 . tests were ok , the cam works smoth , magz are OK .
i have a Zeiss 10/100 f 2 that will cover the 16 mm , and some Nikon ( it s mounted Nikons too ) that will cover the 35 mm .
i will shoot in 16 and 35 , also i ll use a Bolex for some effects .
- any idea about the video assist ? i need to fix one , but i can t afford something complicated , i tried with a spy cam , the result is bad , maybe someone tried this before ?
- if i use the Zeiss ( that cover the 16 ) on 35 films , i will get what i see ? ( the circular crop )
thanks
E
#2 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 05 June 2007 - 05:25 AM
16 mm lenses may not cover 35. It depends on the focal length but the average/short ones will not cover. If you're lucky, the long ones may cover. Test them. But the other way round would work great : using 35 mm lenses for 16. The best choice.
#3 Kenny N Suleimanagich
  • 902 posts
Posted 05 June 2007 - 11:58 PM
Hey "Cahl", it is necessary that you change your name to First and Last name as stated in the forum guidelines. To do so, you can access an editing form in "My Controls"
Thank you.
