Standard monitor settings?
#1 Maty Grosman
Maty Grosman
  • 8 posts
Posted 05 June 2007 - 08:10 PM
Hey everyone,
I've just joined an independent 'no-budget' production as a PA; most crew members (including myself) have little or no experience, so it's mostly 'learn as you go'. The first shooting day raised quite a few questions in my head, and I was hoping to find some answers here.
My main concern was when the Gaffer and DP were trying to set up the lighting; the image on the camera monitor (a digital consumer camera) and on the field monitor (just a regular TV set they were using) differed greatly in brightness and in contrast. The solution they came up with was to adjust the monitor's settings to resemble those of the camera monitor; however, it just did not seem right to me--camera monitors just seem to be of very high contrast and even differ from one camera to the other, and besides, I thought that the whole idea of using a monitor was to see the image as it should be, rather than as it appears through the camera monitor.
I therefore thought that there must be some 'standard' or 'default' monitor settings that would be a sort of consensus amongst all monitors and TV sets. This seems to make sense, for otherwise the same footage would appear different from set to set, and one would be unable to communicate the image as he wants it to appear.
Well, that's as far as my commonsense goes... I would appreciate if anyone could let me know if there are any flaws in this reasoning, and, if there is a standard, where could I find more information about it.
Maty
#2 David Regan
David Regan
  • 218 posts
Posted 05 June 2007 - 10:13 PM
A monitor is calibrated using color bars, which ensure the footage will look the same on any properly calibrated monitor. On a professional field monitor, you can easily make adjustments of contrast, chroma (color), brightness, and hue (phase) following certain procedures, which are explained in detail at the following link. http://www.cinematog...?showtopic=6891
However, given that you are using a TV, you may or may not have the above adjustment options, or they will be available in some cruder fashion. Having never done this with a standard TV I'm not sure which options you'll have.
Hopefully this has helped you understand how the process works, as for actually doing it in your situation it may be tricky. Ideally you would rent a professional monitor, it would make life much easier, but if you have no budget perhaps you can find someone who owns one you can use or rent for a reduced price.
Good Luck
#3 Maty Grosman
Maty Grosman
  • 8 posts
Posted 06 June 2007 - 10:25 AM
Thanks for the reply, David.
The link was very helpful. I've done a bit of browsing on the subject, and it seems that the method for clibrating a TV set is the same.
