Minimum specs for HD
#1 Galen Carter-Jeffrey
  • 129 posts
Posted 12 June 2007 - 10:52 AM
I am buying a new mac with the intention of editing HD. Are there minimum specs I should keep in mind? The two most promising options are the 15" macbook pro or a macpro Tower.
15" macbook Pro $2,299
2.4 GHz intel core 2 GB ram
MacPro $2,568 (would also need to buy a monitor)
Two 2.66 GHz Dual Core
2GB ram
#2 Keith Mottram
Keith Mottram
  • 824 posts
Posted 14 June 2007 - 05:34 AM
2GB ram
I get asked this all the time. if you want to edit seriously then get a tower upgrade the graphics card to the ATI Radeon X1900 XT, get 4 gigs of ram, a couple of monitors and at a minimum fill your chasis with drives raid them and put your system on an external drive.
or if you are going to be doing a bit of 'offline' sufing the net and doing email/ word etc get a macbook.
the word 'intention' is the word you have to think most about.
#3 Daniel Smith
Daniel Smith
  • 791 posts
Posted 14 June 2007 - 07:15 AM
Sorry for butting in here, but I have the same question, only for a PC.
Keith, I'm building a grands worth of PC later on this year with the following specs:
1x 2.66GHz Pentium Duo
2x 1GB 1066MHz RAM
1x 150GB 10,000RPM Primary Hard Drive (SATA) (For holding the software, i.e. premiere pro)
1x 500GB 7,2000RPM Hard Drive (SATA) (For holding the video)
Nvidia Geforce 8600
I'm not going to use this primarily for editing HD, just as a backup solution for 'at home'.
Are 7,200RPM SATA drives even capable of reading/writing uncompressed 1080x1440 footage? I remember on a recent shoot when recording via a HD-SDI output we had to use a special server to do it with a RAID system.
Is this no good or, could I get away with it? ~Thanks.
(And tnx Galen aswell)
Edited by Daniel Ashley-Smith, 14 June 2007 - 07:17 AM.
#4 Keith Mottram
Keith Mottram
  • 824 posts
Posted 05 July 2007 - 11:43 AM
2x 1GB 1066MHz RAM
Nvidia Geforce 8600
Sorry Daniel, only just noticed this, reading writing uncompressed footage is not possible without a raided drive system. Although I don't know your PC enclosure it may be possible for you to have a series of drives raided internally. If you can fit two drives internally then an old trick is to have your system disc on an external drive connected by firewire (though as a pc you may not have a firewire card, but a quick USB2 should surfice) and then you could raid two 150gb 10,000 rpm for online 4.2.2 8 bit at a push. I would need to have a bit more information about specifics regarding codecs and capture card to work out exactly what you need and as it's for a PC Phil Rhodes will be able to chime in then with some tried and tested choices. If you have got a budget as tight as this you should think about working compressed- but with good wavelet and then you'll get very acceptable results. HDV of course will be fine with your specs. Give more info and you'll get more!
keith
