wireing a battery
14 replies to this topic
#1 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 14 June 2007 - 06:34 PM
does anybody have a sketch or Do-It-Yourself on how to wire a 12v battery to a 4-pin XLR? Any recommendations?
#2 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 14 June 2007 - 06:53 PM
I spelled wiring incorrectly, and the reason I ask is would anybody have bought this camera for this price?
http://cgi.ebay.com/...em=130093642313
#3 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 14 June 2007 - 08:00 PM
I spelled wiring incorrectly, and the reason I ask is would anybody have bought this camera for this price?...
Pin 1 is negative and pin 4 is positive.
If the camera has the old governor motor, pins 2 and 3 might be wired to pilot and bloop.
#4 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 15 June 2007 - 06:23 PM
Does this look right? And then I just hook the wires up to their respective + - on any 12v battery, and doing nothing with the middle wires?
thanks
#5 Clive Tobin
Clive Tobin
  • 402 posts
Posted 18 June 2007 - 06:54 PM
Does this look right? And then I just hook the wires up to their respective + - on any 12v battery, and doing nothing with the middle wires?...
Right.
#6 Daniel Madsen
Daniel Madsen
  • 201 posts
  • Boston
Posted 18 June 2007 - 07:19 PM
pilot and bloop...what is this??? Have any of you used a resistor to lower a batteries voltage so it can be used with a smaller camera?
Edited by Danielle Frankinshten, 18 June 2007 - 07:21 PM.
#7 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 18 June 2007 - 08:51 PM
Hi, If your new motor is crystal speed, you don't need pilot and bloop. The photo looks like a Beala crystal motor. All you need is a 4 pin cable where only pins one and four are connected each side. Pins 2 and 3 are not used in this case.
#8 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 19 June 2007 - 12:23 AM
Thank you Mr. O'Doherty... As for the battery, are there any recommendations and where I can buy one?
thanks
#9 Bernie O'Doherty
Bernie O'Doherty
  • 232 posts
  • Newark Valley, NY
Posted 19 June 2007 - 05:51 AM
There are many choices. If you want cheapness go to Bescor (google 'em) and get a 12v lead-acid.
They are heavier than NiCad and won't last as long either, but they fit the bill for many people.
Bescor also sells either NiCad or the more advanced Nickel Metal-Hydride. See if they can supply them with 4 pin XLR plugs. If not, do it yourself, it's easy. A soldering iron, solder, cutter pliers, stripping pliers, and the courage of a lion are all that is required.
Cheers, Bernie
#10 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 19 June 2007 - 07:42 AM
I'd add an inline fuse as well, to protect against a short circuit. A lead-acid battery can output enormous current, enough to melt any camera power cable into a smouldering puddle.
#11 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 19 June 2007 - 11:05 AM
Sounds good, thanks for all the help guys... hopefully I'll be up and running by the end of the week.
#12 Clive Tobin
Clive Tobin
  • 402 posts
Posted 20 June 2007 - 09:48 PM
[quote name='Joshua Dannais' date='Jun 18 2007, 10:23 PM' post='178970']
... As for the battery, are there any recommendations and where I can buy one? .../quote]
We have battery belts with a good PowerSonic automatic-cutoff charger for $225. See the website page at http://www.tobincine...com/page10.html . This charges through the reliable XLR plug not the lousy cigarette lighter one.
I am assuming you are in the USA since we are forbidden now to send batteries through the Post Office to overseas, and the other carriers are very expensive.
#13 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 21 June 2007 - 03:36 PM
Thanks for the info on the battery belt... I have one more question pertaining to the motor, yes it is a beala motor and I know it is capable of "wild" speeds of 6-40fps, but how is this setting selected? thanks
#14 Joshua Dannais
Joshua Dannais
  • 91 posts
Posted 22 June 2007 - 04:35 PM
please disregard the last post, figured it out.
#15 Joel Whybrow
Joel Whybrow
  • 11 posts
Posted 20 July 2007 - 12:12 PM
Sorry to hijack the thread, but rather than starting a new one, will this wiring configuration be the same for a Arri 16s, i.e, pin1 power pin4 ground?
Also, would 9v work ok for a governer 24fps motor or will it need to be exactly 8v 3.6a?
-Joel
