Low contrast look.
#1 James Rydings
James Rydings
  • 38 posts
  • Los Angeles, California
Posted 27 June 2007 - 03:21 PM
I am shooting a short film on Super 16 in Tuscany Italy. I want to give it a low contrast, natural, soft look. I want to shoot with Cooke lenses but it will end up being Zeiss as the production can get them for free, so I will probably use a little diffusion. I am uncertain on which stock to use. My first thought is the Expression or Eterna, but being super 16 I would rather shoot on a slow speed stock around 100-200. Are there any slower speed low contrast stocks? Or should I just shoot on the 7217 or 7212 (maybe even the 7201) and pull process, or use a low contrast filter? Also what are the differences between the Eterna and the Expression?
Posted 27 June 2007 - 03:30 PM
Eterna 250D, 250T, and 500T are fairly low in contrast, though not quite as low as Kodak Expression 500T or Fuji Eterna 400T.
But less contrasty than Kodak Vision-2 50D, 100T, 200T, 250D, 500T (which are not that contrasty either...) But the old Super-F Fuji F64D and F125T are more contrasty than regular Vision-2.
So lowest contrast: Fuji Eterna 400T, Kodak Expression 500T
Next lowest: Fuji Eterna 250D, 250T, 500T, Reala 500D
Next lowest: all the other Kodak Vision-2 stocks
More contrasty: Fuji F-64D, F-125T, Kodak Vision 74, 79
Most contrasty: Fuji Vivid 160T
If you want the finest grain, lowest contrast, I'd use Kodak 50D (7201) with an UltraCon filter or overexpose and pull-process. Otherwise, I'd use Fuji Eterna 250D, maybe with the UltraCon or overexposed and pulled (which would reduce grain).
#3 James Rydings
James Rydings
  • 38 posts
Posted 27 June 2007 - 08:41 PM
Thank you for your speady reply. I think I will use the 50D for the exteriors and the 250D for the interiors. However what would be the difference between pull processing and using the UltraCon Filter? I dont want the blacks to go milky. I am thinking of over-exposing 1 1/2 stop and pulling 1 stop. How does that sound?
#4 David Mullen ASC
Posted 27 June 2007 - 09:06 PM
Fine. You'll get milkier blacks from an UltraCon more than you would from overexposing + pull-processing, which is more about lowering contrast.
