HVX "Shutter Angle"
#1 Drew Hoffman
Drew Hoffman
  • 57 posts
  • Chicago, IL
Posted 02 July 2007 - 04:47 AM
I'm in pre-production on a short that features a scene which (under perfect circumstances) would be served very well by cutting the shutter angle and making the scene look a little more hectic. However, since we'll be shooting on the HVX, with (God I hope) P2 cards... I was wondering how successful others have been replicating such an effect digitally.
  • 20068 posts
Posted 02 July 2007 - 09:40 AM
Should be simple to do with any video camera -- just use shutter speeds shorter than 1/100.
At 24P, 1/100 would be close to a 90 degree effect and 1/200 close to a 45 degree effect.
#3 Chris Keth
Posted 02 July 2007 - 02:22 PM
The HVX does it pretty well. In film mdoe it even used shutter angle terminology rather than shutter speeds.
#4 e gustavo petersen
e gustavo petersen
  • 128 posts
  • LA | CA | USA
Posted 02 July 2007 - 02:39 PM
If by "replicating such an effect digitally" means "can this be emulated in post?" that can prove tricky. I don't think it can be done easily since what you're capturing in camera will have the temporal artifacts of a wider shutter. Meaning the blur associated with a 180° shutter, for example, would have to be removed and and the image sharpened. The removal of the blur is the tricky part. You might want to try a "sharpen" plugin with perhaps pulling frames or speeding up the footage to give it some edge and jumpiness.
#5 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 06 July 2007 - 12:21 PM
In the HVX Scene File menu setting, go to Synchro Scan, push "set" (yes) button and it should show 180 degrees. Go to "yes" and then find the shutter angle you would like. 10 degrees being really sharp motion like 1/2000 almost. You loose about 4 1/2 stops.
Make sure the camera is in FILM CAM mode.
