rx lenses on nonreflex camera
#1 ishan vernallis
ishan vernallis
  • 48 posts
Posted 02 July 2007 - 11:00 AM
question:
I've been reading here and there
that it is possible to use switar RX lenses
on nonreflex cameras, if they are over 50mm.
In my case I am particularly wondering about
using them on an Eclair ACL.
Has anyone had good results with this?
Is there a compromise in picture quality?
Seems like if you're wanting to keep the glass small
and relatively inexpensive, that the switar AR lenses are a good option.
Yet, most of these are very old and not as sharp as the newer
switar macro lenses?
any input would be most appreciated.
thanks.
#2 ishan vernallis
ishan vernallis
  • 48 posts
Posted 02 July 2007 - 11:13 AM
whooops.
just now saw the pdf on the preceeding zeiss lens post.
which more or less explained what I was wondering.
Still though, curious if any acl shooters bother with the rx switars?
thanks.
#3 ishan vernallis
ishan vernallis
  • 48 posts
Posted 02 July 2007 - 12:18 PM
o.k.
Am I very confused,
or is this seller way off mark...
They just wrote to me regarding a
Bolex Kern Macro-Switar 26mm f1.1 RX Lens:
"The 26mm f1.1 lens should be ok for standard 16mm or super 16mm for your Eclair acl. Rx lenses are needed for Your Eclair."
I have never heard that The Acl needed RX lenses.
Did I miss something along the way?
#4 Clive Tobin
Clive Tobin
  • 402 posts
  • Spokane Valley, WA, USA
Posted 02 July 2007 - 07:18 PM
o.k. Am I very confused,
The seller is spouting some bovine excrement.
#5 Nick Mulder
Nick Mulder
  • 1023 posts
  • Auckland, New Zealand
Posted 02 July 2007 - 07:30 PM
You'll find that the Switars above 50mm aren't even marked as RX ... ie. they are just 16mm lenses ...
The 50mm I think were branded RX though, maybe to force peoples hands into not considering other brands ?
I'm pretty sure the same rule fro using nonRX on RX cams applies in reverse ... Just stop it down a bit
