Standard mount lenses on 16BL
7 replies to this topic
#1 Kenny N Suleimanagich
  • 902 posts
Posted 04 July 2007 - 03:27 AM
I read somewhere that if using std mount lenses on a 16BL, you run into problems with the back element hitting the shutter. However, if they have the same flange focal distance wouldn't they be the same protrudance into the camera? Does anyone know any more info on this topic?
#2 Kenny N Suleimanagich
  • 902 posts
Posted 04 July 2007 - 04:41 AM
Nevermind I found out you cant!
#3 Kenny N Suleimanagich
  • 902 posts
Posted 04 July 2007 - 04:42 AM
#4 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 05 July 2007 - 01:19 PM
When I was at Sawyer Camera, we had two 10mm Schneider Cinegons.
One cleared the mirror on a 16BL, the other didn't.
The one that didn't clear had a flange around the rear element, while the other one didn't have the flange.
So some lenses clear, some don't.
Flange focal distance has no direct relationship to the rear focus of a lens, which is the distance from the rear element to the film plane.
You would need the Prime Lens Blimp if you intend to shoot with sync sound.
"Nevermind I found out you cant!"
If that's related to the lens blimp, that's a completely diferent issue.
#5 Kenny N Suleimanagich
  • 902 posts
Posted 05 July 2007 - 03:15 PM
I just didnt know as to whether or not you could. I'd rather not take the risk and buy glass that wont fit. The lens blimp isn't much of an issue.
#6 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 07 July 2007 - 01:42 PM
Arri used to have lists of what fits. They would be listed in a 16BL manual. It might be the same as the SR.
Off hand the 8mm Zeiss standard fits, the 9mm and 12.5mm Cooke Kinetal won't, longer Kinetals will.
#7 Gus Sacks
Gus Sacks
  • 287 posts
Posted 07 July 2007 - 03:13 PM
http://emrl.com/reso...a/arri_16bl.pdf
Pages 4/5 list them. I'd just be a bit wary of using the wides with the lens blimp. I don't really know how that would work.
#8 Leo Anthony Vale
Leo Anthony Vale
  • 2010 posts
  • Pittsburgh PA
Posted 09 July 2007 - 02:07 PM
The Universal lens blimp was designed to be osed with the listed lenses, therefore it should work fine with the 8mm Zeiss and 10mm Cinegon. This is not the same blimp thats on the 12-120mm Angie.
But changing lens will be a pain in the butt.
