200ft magazines
#1 kevin jackman
kevin jackman
  • 350 posts
Posted 04 July 2007 - 03:35 PM
i understand that there were 200ft magazines from kodak and an aftermarket one. does anybody know anything about them? is the kodak one reloadable?are there any mags for sale,especially the aftermarket ones?
#2 George Patoulidis
George Patoulidis
  • 30 posts
  • Greece
Posted 04 July 2007 - 05:31 PM
The 200 ft cartridges from Kodak are not reloadable. (well, there are people that say that they can reload them... anyway...).
Kodak stopped the production of these carts at 1996-1997 (due to low demand).
The reloadable 200ft magazine (SD-60 or something) is for the Beaulieu sound cameras (6-7-9008 cameras).
It was made by Ritter in Germany, and it's very rare and expensive. A standard Beaulieu 6008s also needs modifications to accept it.
I have such an example (a Ritter-Beaulieu 6008s) but I'm missing the mag! <_<
#3 Bernhard Zitz
Bernhard Zitz
  • 342 posts
  • Z├╝rich, Switzerland
Posted 09 July 2007 - 05:35 PM
The kodak 200ft mag was designed for one way use. I opened one; it seemed impossible to reload it. It has a funny spring mechanisme that makes it nearly impossible to reload it by opening.
another thing I imagined was to unwind an cut out most of the old film, let some handles at the end and the start and tape the freshh stuff in between and rewind. No idea if this works, it certainly would scratch a little, don't know if it's a suitable task to do in a changing-bag, and your workflow wouldn't realy benefit compared to the use of 50ft-cardridges.
cheers, bernhard
#4 Tony Hudson
Tony Hudson
  • 22 posts
Posted 05 September 2007 - 05:57 PM
It's too hard trying to reload the Kodak mags.
I owned some of those Beaulieu/Ritter cameras with 200ft mags at one time, but they are quite heavy. There are some pics on this web-page of my camera:
Beaulieu SD8 system.
They were great for long take shots and had good image stability but it ate the batteries.
Edited by Tony Hudson, 05 September 2007 - 06:00 PM.
#5 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 05 September 2007 - 06:19 PM
Double super 8 is the only hassle free way to shoot more then 50ft of S8. You can shoot 100ft 16mm spools, 100ft on each side. so about 5 min of filming on each side, or 10 minutes total on the spool.
#6 kevin jackman
kevin jackman
  • 350 posts
Posted 05 September 2007 - 06:35 PM
actually if you go bolex or pathe you can use the magazine and shoot 400ft rolls
#7 Mitch Perkins
Mitch Perkins
  • 66 posts
Posted 06 September 2007 - 05:41 PM
i understand that there were 200ft magazines from kodak [...] is the kodak one reloadable?
I had 5 or 6 of them when I had access to (long) short-ends in 50' S8 cartridges. Kodak press tapes went smoothly through mag, camera and processor. Shot thousands of feet with only one or two jams. Watch the counter and listen for the splice, or throw caution to the wind and allow random fades to/from white.
You have to *really* want to do it. ~:?)
Then again, once you've figured it out...
Crack it carefully in half, practice loading with leader. Only one path makes sense. The little band spring is ingenious and diabolical - you hold the feed reel and backwind the takeup reel, after you hook the tiny tooth into the invisible slot, then attach head of film...I forget how to do it, but you need a darkroom, not a bag.
Mitch
Edited by Mitch Perkins, 06 September 2007 - 05:45 PM.
