white walls
13 replies to this topic
#1 Natalie Saito
Natalie Saito
  • 107 posts
Posted 05 July 2007 - 05:06 PM
im shooting in a room that has all white walls..inc the ceiling. it'll work for a high key setting but that's far from what im trying to accomplish--night low key. what is the best approach when it comes to equipment, technique? thanks for reading!
#2 Xavier Plaza
Xavier Plaza
  • 288 posts
  • Guayaquil - Ecuador
Posted 05 July 2007 - 05:42 PM
Hi Natalie, well when you work in a white room for a low key night, the best you can do is use a lot of black flags and black fabrics..., i didn't use bounce lights perhaps thats ruin your plans... Directional light i guess is your way, maybe fresnels and kinos, i don't know what you wanna do, if you can be more specific, perhaps we can help you more...
Cheers
#3 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 05 July 2007 - 06:05 PM
Try to keep your lighting from spilling onto the background and far wall as possible. Use flags, snoots, and blackwrap to aim your lighting only onto your subjects. With soft sources like diffusion frames or Chimeras you can use eggcrates to control the spill without taking up too much space in the room. Hang duvetyn on the off-camera walls and floor to control ambient light.
I little bit of art direction can really save you, too. Utilize artwork on the walls, bookcases, plants, whatever is appropriate for the location to break up the plain white background.
Sometimes you can take a sort of "inverted" approach to the lighting, letting sunlight (real or artificial) or spill from practicals illiminate the walls with patterns or pools of light, and then slightly underexpose your subjects in the middleground for a semi-silhouetted look. If you expose carefully this can look natural and dramatic (sometimes a little edgelight on your subjects can help with this).
#4 Natalie Saito
Natalie Saito
  • 107 posts
Posted 05 July 2007 - 06:12 PM
Cheers
yeah i figured bounce will ruin the shot..perhaps using a soft light for bounce may be acceptable for CU maybe MS. using 2 main motivated light sources--moonlight from the window and incandescent hanging light a bit close to to the opposite end not far from a door. the front of the door will have a motivated porch light. in any case i'd need to mock moonlight and the porch light. the light itself will be in some shots..WS..but obviously it wont be bright enough alone. thanks a bunch!
Edited by NSaito, 05 July 2007 - 06:14 PM.
#5 Xavier Plaza
Xavier Plaza
  • 288 posts
Posted 05 July 2007 - 10:02 PM
As Michael says you can do a very good and close work with art department, this guys could be a very good help to save your scene, a properly mixing of decoration and furniture help you a lot. Just one more thing, I assume when you talk "moonlight", i imagine your source (perhaps your key) coming through the window, just one tip, you can do two things (my point of view), first see how the light bounce into the room, perhaps helps a lot to create an ambient light (low key) or perhaps blow all the room, here you can use black fabric on the floor blocking the light and handle it...
Good Luck
#6 Kevin Zanit
Kevin Zanit
  • 1223 posts
  • LA
Posted 06 July 2007 - 12:46 AM
Painting always solves this problem relatively easily.
Also, do a search as this topic has been discussed quite a bit on here, and there are some good tips in those various threads.
Kevin
#7 Natalie Saito
Natalie Saito
  • 107 posts
Posted 07 July 2007 - 03:36 PM
yeah painting the room black is not an option. i was suggested yesterday actually to use a bunch of duvetyne or black trash bags...but that will require a a heck of a lot either to cover the whole room. i was thinking i can use them as negative fill, to control light spill. i dont think i need to "black out" the entire room. i dont think adding too many set props will be approp. for this particular shoot but a couple items to control light wont hurt.
thanks for your help! --Natalie
Edited by NSaito, 07 July 2007 - 03:38 PM.
#8 janusz sikora
janusz sikora
  • 82 posts
Posted 08 July 2007 - 07:52 PM
Natalie...
it is going to be very difficult to create Low Key in tight location with white walls.. Simply not much room for all those light control accessories.
You can still do it easy if you don't mind going "hard"... Hard Light... Just pin spot your action areas with fresnells... you will not have to deal with light leak like you would had you gone "soft".
You will still have to use Flags (but not as many) and Black Wrap... wrap the instrument's Barndoors with Black Wrap where they leak light.
#9 Natalie Saito
Natalie Saito
  • 107 posts
Posted 11 July 2007 - 02:11 PM
i fig when shooting WS the black bags and duvetyne may possibly be seen in the shot. the smaller fresnel spot lights seem to be a better choice with the usual flags, nets, scrim kit + black wrap. that is the toughest part to light..the lights coming from outside seem easier to work with. thanks.
Edited by NSaito, 11 July 2007 - 02:14 PM.
#10 Jimmy Browning
Jimmy Browning
  • 42 posts
Posted 11 July 2007 - 06:25 PM
He didn't say paint the room black, he just said paint it. A different color. One that doesn't reflect as much light, and works well with the colors you are using in set design.
Who knows, whoever owns the place might be happy to let you give their boring white-walled room a free paint job to liven it up a bit.
#11 Xavier Plaza
Xavier Plaza
  • 288 posts
Posted 11 July 2007 - 10:19 PM
this idea sound logical and with a perfect combination between art department and you could be a interesting proposal...
Good Luck
#12 Robert Hughes
Robert Hughes
  • 873 posts
  • Sound Department
  • Minneapolis
Posted 11 July 2007 - 10:31 PM
Stanley Kubrick, in Barry Lyndon, reportedly hung thin black mesh in front of background walls to help talent stand out during daytime interior shots.
Edited by Robert Hughes, 11 July 2007 - 10:32 PM.
#13 Natalie Saito
Natalie Saito
  • 107 posts
Posted 12 July 2007 - 01:56 PM
its an apt so i'd probably have to paint it back to white. the room isn't small. if it were my house i'd probably go with painting it.
#14 Xavier Plaza
Xavier Plaza
  • 288 posts
Posted 12 July 2007 - 02:14 PM
Maybe this sound ironic but i never allow no one (including me) shooting at my house, never... I guess we always know how the produccion do with a locations, sometime it could be a catastrophe, you know ;)
