1.85 frame
#1 roy farag
roy farag
  • 14 posts
Posted 08 July 2007 - 02:27 PM
hi all
nead help on what is the best way how to a chive a frame size of 1.85 in videocamera dsr450
thank you for your comments
roy
#2 Chris Keth
Posted 08 July 2007 - 04:58 PM
hi all
roy
Either crop the frame or use an anamorphic adapter on the lens and stretch the frame in post.
I would crop.
#3 roy farag
roy farag
  • 14 posts
Posted 09 July 2007 - 02:45 AM
yes i eill crop but any suggestions on how to?
#4 Chris Keth
Posted 09 July 2007 - 02:03 PM
Make measured tape lines on your monitor and then crop the footage to match those lines in post. Final cut does it very easily with a widescreen matte.
#5 Richard Vialet
Richard Vialet
  • 133 posts
  • Hollywood, CA
Posted 10 July 2007 - 01:27 AM
there is an option in the operations-->display menu where you can set the specific aspect ratio u want. I think the option is called "Marker". You can use it to create any aspect ratio you want and it will show up as a sort of electronic "groundglass" in the viewfinder and any monitor output. The most exact way to use this is to frame a framing chart and set the "marker" to that to get an exact 1.85:1 frame. Record the framing chart and then crop it in post. Hope this helps.
#6 Chris Keth
Posted 10 July 2007 - 12:44 PM
Does that camera give you 1.85? I thought you could only get 1.78.
#7 Richard Vialet
Richard Vialet
  • 133 posts
  • Hollywood, CA
Posted 10 July 2007 - 03:15 PM
Yea, the camera is native 1.78:1. But it has the option of giving you custom framelines in the viewfinder and the monitor output that you can set to whatever you want. I was giddy like a child when I realized this, lol.
#8 Chris Keth
Posted 10 July 2007 - 04:05 PM
Cool. Shows you how much I've used that cam :P
#9 roy farag
roy farag
  • 14 posts
Posted 11 July 2007 - 10:43 AM
did it done it done! changed the aspect of frame size throwout the viewfinder scalling
thanx
